Old 03-12-2013, 01:58 PM   #1
Exterior Lightbulb Replacement
Anyone know what the correct replacement bulb is for the exterior light (controlled by the switch just inside the door)? I would assume all of the models are the same, but I have a 318BHS if needed.
Thanks.
John & Amy
jnamadison is offline   Reply With Quote
Old 03-12-2013, 02:51 PM   #2
VinceU's Avatar
Thanks.
Just bought some in Wal-Mart. Used 1103LL, low wattage, long life with two pins. The 1156 is similar but will melt the lense. Check yours first for same fixture. Mine is typical.
Old 03-13-2013, 08:50 AM   #3
Ours kept burning out, so we replaced it with an LED light, and took care of that problem.
Laura is offline   Reply With Quote
Old 03-13-2013, 09:33 AM   #4
Thank you both for the replies.
Laura,
We would like to go in that direction as well. Do you remember what type of LED you got for the light?
Thanks again.
John & Amy
Old 03-13-2013, 04:47 PM   #5
No, sorry, I just got one that was at the store at the RV park.
Old 03-13-2013, 05:12 PM   #6
Hope you had better luck changing them than I did. One of our "Scare" lights needed a new bulb and some jerk @ the factory had filled the lens holes where the screws go with caulking. Only took 30 minutes to dig the caulking out. Still have to check the one on the other side.
