Old 03-02-2012, 08:56 PM   #1
exterior TV hanger specs? La Crosse 318
Does anyone know what the weight limit of the exterior TV hanger on the Lacrosse 318 is?
savdog is offline   Reply With Quote
Old 03-02-2012, 10:00 PM   #2
TTNewbees's Avatar
Not sure about weight restriction but I hang this tv on it to watch football games, assume its same hanger that's on my Lacrosse.
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 03-03-2012, 08:35 AM   #3
grhodes50's Avatar
I'm not sure and never really thought about it. I have on several occasions taken the tv from the tt and mounted it outside with no problems.
Hopefully RV Guy will post the weight limits.
Most LCD/LED tv's are light weight. I believe the 42" in my house is around 50 lbs. If you're thinking that might be too much weight or if you're wanting to go bigger, you could always set the tv on a table next to the outside hookups.
P.S. Nice looking entertainment center TTNewbees!
Gary & Trish
2016 Nights Camped - 9
Old 03-03-2012, 09:29 AM   #4
My entertainment center looks the same as TTnewbies. That is what you get if you do not have the fireplace on the touring edition. I am so glad I do not have the fireplace!
Laura is offline   Reply With Quote
Old 03-03-2012, 10:06 AM   #5
Commercial Member
The exterior bracket was designed to hold the 26" TV that is standard on most LaCrosse models. Typically, these weigh less than 30 pounds. We do not recommend hanging anything heavier than 30 pounds on these brackets.
RV Guy is offline   Reply With Quote
