Old 03-22-2013, 02:31 PM   #1
Toy-aholic
EZ lube hubs
I just picked up my '13 Crusader and after doing the walk thru, the tech told me my Dexter axles did not have EZ lube bearings/hubs( I asked about them)...claimed they were regular Bearing Buddies...I think he's wrong....anybody here know anything on this?
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 03-22-2013, 02:39 PM   #2
TURBS's Avatar
Don't know for sure on yours but mine if you pop off the little cap on the wheel cover the grease zerk will be mounted right to the axle shaft. Drilled and tapped.
If not its a bearing buddy.
My spec sheet on my sabre specifically said "ez lube bearings"
Old 03-22-2013, 02:47 PM   #3
As you no doubt know, the PrimeTime "Features" list for Crusader says they are. He's probably wrong...but easy enough to look. If they're not, take it back!
Old 03-22-2013, 09:26 PM   #4
Toy-aholic
ok, I just verified it....it DOES have EZlubes....guess the tech wasn't well informed...he also had trouble demonstrating the auto leveling...hmmmm. Glad everything has it's own owner's manual!
