Old 04-24-2012, 11:55 AM   #1
Rustymax's Avatar
Location: Close to North / South Carolina border and Blue Ridge Mountains
Fast charging batteries
I was dry camping for the first time in my new travel trailer last week and I have a question about charging batteries.
I am wondering if I bring my battery charger and plug it directly into the generator will it charge the batteries faster than the trailer inverter. Any experience here?
My generator(s) is a Yamaha 2000is and has two 110 plug outlets. Additionally this generator has a special charging cable for battery only charging. I tried to fast charge my dual battery setup by connecting the alligator clip to the battery terminals but this didnít appear to produce a much faster charge than using the trailer inverter, perhaps I am overlooking something, Iím a newbie.
Any tips for keeping the batteries lasting longer when dry camping?
Rustymax is offline   Reply With Quote
Old 04-24-2012, 01:18 PM   #2
bikendan's Avatar
First, the trailer has a converter, not an inverter. Many newbies get them mixed up.
Second, your converter will charge about as good as a separate charger.
Third, the 12v cables that come with the Yamaha, are the worst option to charge the battery and are only useful for emergency uses.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-24-2012, 01:50 PM   #3
TURBS's Avatar
Bikendan speak the truth.
Old 04-24-2012, 02:02 PM   #4
Curious. Why are the 12V cables that come with the Honda a bad option?
2012 Grey Wolf 19RR
2008 Dodge 2500 CTD
Nights camped 2012 - 35
Nights camped 2013 - 46
rkswyo is offline   Reply With Quote
Old 04-24-2012, 02:08 PM   #5
How did Honda get here? OP said he had a Yamaha generator. Doesn't matter, what I remember of generator specs, the 12 volt cable is good for max of about 10 amps max, on most brands. Usually that is used to recharge the battery in electric start models. The converter in the trailer could go as high as 50, or more, depending on model of the converter, of course.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-24-2012, 02:08 PM   #6
Herk7769's Avatar
I seem to remember a thread that proved to me that that was true.
Now I need to go back and find it.
Bummer.
HAM CALLSIGN - KC3FFW
Old 04-24-2012, 02:10 PM   #7
Herk7769's Avatar
Ah, that was it. The amp limit on the DC portion of the generator.
That is why I use a dedicated 120 VAC Ship-n-Shore charger plugged into the AC outlet on my Yamaha 3000.
Old 04-24-2012, 03:31 PM   #8
Triguy's Avatar
I use a 40amp three-stage smart charger and prefer it over the converter - a wfco 55amp.
I don't know what converter you have, but consider that the wfco 55-amp in my trailer doesn't seem to go into the 14v bulk mode at all. It stays at 13.6v and will drop to its float 13.2v after a couple of days (measured at the converter). I've read that this issue about not getting to the 14v bulk mode is common with the wfco 55amp.
Also, because I have Trojan batteries that need 14.8v, the converter is less capable as its upper limit is 14.4v in bulk (which it won't reach anyway ).
I can't speak to the generator but I do think there is a general performance difference between a separate charger and the converter.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-24-2012, 06:45 PM   #9
kz08h5's Avatar
You need to read the 12 Volt Side:
The 12volt Side of Life (Part 1)
This is a good tutorial on batteries and charging. The main problem with RV OEM charging systems is that they are nothing more than trickle chargers. You will never get a full charge. I have ruined on battery not knowing any better. I now use a Schumaker 3 stage charger each morning to charge the battery. Also, don't go by the status panel in the RV to determine battery charge.
As far as the 12v port on the generator, it will basically to the same thing as your RV converter. It will never fully charge your battery.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 04-24-2012, 06:50 PM   #10
Rugged Brown's Avatar
So, Am I hearing that a good dedicated battery charger connected to the said Yamaha 2000 generator is better than the RV converter. Can you give it to me in laymens's language.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
battery
