Old 04-20-2012, 09:01 PM   #1
Fire place
Just picked up my 292 bhs touring edition was wondering where the remote is for the fireplace I see that you can set a timer for the unit but you need a remote for it. It also will adjust the fan levels. Any ideas
Bunk man is offline   Reply With Quote
Old 04-20-2012, 09:14 PM   #2
Herk7769's Avatar
What is the model number and manufacturer of your fireplace?
Some models have the remote; other models don't; and some that were supposed to have them didn't and should be provided as a "short ship" under warranty.
www.twinstarhome.com
HAM CALLSIGN - KC3FFW
Old 04-21-2012, 09:30 AM   #3
rracer5's Avatar
As covered in previous threads, PT does NOT usually provide remotes with the fireplace due to instances of remote interfering with other electronics in the TT (ie; tv, stereo). However, some who did get the remote have stated that they have not had any interference problems. So, I would contact PT (www.primetimerv.com) and see if they will send the remote.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-21-2012, 11:20 AM   #4
Herk7769's Avatar
I use my remote all the time and never had a problem with anything.
So far kicking the heat up has not rolled out my awning either.
Old 04-21-2012, 10:55 PM   #5
So read the owners man for the fire place says it has a remote but did not come with one so any idea on the way to go about getting one
Old 04-21-2012, 11:00 PM   #6
"PT does NOT usually provide remotes with the fireplace due to instances of remote interfering with other electronics"
That is a strange solution to a problem with component compatability. The factory shouldn't be using brands that interfere with one another.
Ours has had no issues.
Bunkman, simply call up your dealer and tell them to get you a remote. It should have come with the camper.
Old 04-21-2012, 11:17 PM   #7
onetonford's Avatar
???? My Wildcat came with remotes for 5 Different devices I wish they were all the same so I could use just 1 universal one....
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 04-22-2012, 07:18 AM   #8
Herk7769's Avatar
If you buy a "learning remote" you can have your wish.
Logitech make one I use on our home entertainment system because the DW has trouble figuring out how each component needs to be set to, say watch a DVD or switch back to TV.
I use this one in our living room. With the correct modules on the line cords it will even dim the lights.
Logitech Harmony® One Advanced Universal Remote
Old 04-22-2012, 06:07 PM   #9
onetonford's Avatar
Herk does it work with remote that uses radio frequency instead of infared and can it work both types?
2011 25 RL Wildcat
Old 04-22-2012, 06:20 PM   #10
Herk7769's Avatar
Not the Harmony One. There are others that will.
