Old 03-30-2013, 12:03 PM   #1
Firestone airbags
In a previous thread 2 people said that the firestone airbags made a huge difference but didn't say why. I have a chevy 2500 and only about 1250 pounds of pin weight. So what will the airbags do for me?
Dave
flyingfarmer is offline   Reply With Quote
Old 03-30-2013, 02:28 PM   #2
jtstromsburg's Avatar
I just had bags added to my F250. They help a lot for my situation. But if your tongue weight is that light, i would think you'd be fine without. I'm a bit heavier then that and could feel the bump stops on some larger bumps. The bags make the 5er feel more stable. I really only notice on bumps, but haven't towed far with them yet.
Ymmv
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 03-30-2013, 02:57 PM   #3
Lynkage's Avatar
I put some on mine and like what they did for the ride. Handles bumps much better.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 03-30-2013, 03:13 PM   #4
Dave
I have AirLift bags on my 1500 Silverado and just use them to get back the 1" I lost from the normal height. My advertised pin wt is 1075#. Don't know what the actual is and am not really concerned. Just wanted the ride height back for headlight aim should we ever tow at night which is not very likely.
Old 03-30-2013, 03:51 PM   #5
ironj's Avatar
when my 250 was stock height, i had them on and it made a considerable difference both with the trailer (1150 tongue weight) and the gooseneck i hauled only a few times....
1. they let me level the truck so my HID's dont singe oncoming drivers retinas
2. they really take away the "swimmy" feeling the trailer sometimes had over wavy roads
3. they seemed to make the truck ride a little better even when unloaded and set to about 5psi...
the only negative i ever had was that they can affect the adjustment of a wdh if your using them in that type of situation.....the bar tension is a function of the head pitch/tilt setting....and raising the truck takes load off the bars
now that i lifted my truck, it has new blocks in the back that intefere with the bag....so im gonna have to modify them a lil (the ears on the blocks that is)
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 03-30-2013, 04:15 PM   #6
GASPEDDLER's Avatar
How much does a pair of bags for the rear cost?
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 03-30-2013, 05:07 PM   #7
I just had a set it'd airlifts installed for $600. Think that's a bit high though....
Joel and Teresa
2016 Sabre 34TBOK
Old 03-30-2013, 05:33 PM   #8
ironj's Avatar
well the bags alone run 3-400 then add in labor and tax....it may be high, but not by a whole lot....
not sure if the price changes a lot based on application though?
Old 03-30-2013, 05:38 PM   #9
Just installed a set on my 2011 F250, $225 with my install.
2021 camped 45 days drove 6500 miles
2020 F350 Extended Cab
2018 Sandpiper 354RET
fkent1 is offline   Reply With Quote
Old 03-30-2013, 05:58 PM   #10
Lynkage's Avatar
I spent about $650 with a continuous duty air compressor. I also use it for the bikes/atv's and if someone ahs a flat. Also have a 5 gal tank with that.
I did my own install.
Shane & Antoinette
Old 03-30-2013, 06:05 PM   #11
ironj's Avatar
Is that for firestone bags? ..heck I never even seen the bags alone that cheap out the Door? Let alone labor ? ...
Who/where did u get those from?
I know a lot a guy's that would jump at that price!
Old 03-30-2013, 10:07 PM   #12
Scratch's Avatar
Guess I was ripped off. Paid 1400 with in-cab adjust-on-the-fly installed by the RV dealer... I like them none the less...
Scratch sends...
'12 nights camped: 12
'13 nights camped: 24
'14 nights camped:
Scratch is offline   Reply With Quote
Old 04-01-2013, 02:41 PM   #13
ironj's Avatar
im assuming that is with an onboard compressor setup as well?....them parts aint cheap especially if they used a high end compressor....just saying
Old 04-01-2013, 03:19 PM   #14
William
WEMig's Avatar
I purchased a set of air rides for my F250 for $300 and installed them myself. You can order them as just a "bolt on" kit. To have them installed is another $300.
2012 Crusader 320RLT
2011 F250 Lariat 6.7L
2016 (19 Nights Camped/1348 Miles)
2015 (38 Nights Camped/3560 Miles)
2014 (28 Nights Camped/1980 Miles)
2013 (30 Nights Camped/1411 Miles)
WEMig is offline   Reply With Quote
Old 04-01-2013, 03:42 PM   #15
golfmedik's Avatar
I bought my Firestones for $270 with free shipping a year ago. Doesn't matter which brand as AirLift, PacBrake or Firestones are good brands. I did stay away from the wireless compressors and went with a Viair 10007 onboard air system and absolutely love it.
2012 Sandpiper 365SAQ weighing @ 15k, Onan, 2nd air, slide toppers, TST
2013 F350 6.7L Lariat 4x4 CC DRW,Viair 1007, Ride-Rites, Edge CTS, B&W
2001 Chevy 3500CC DRW 4x4, 8.1L, 4.10 gears w/ Detroit TrueTrac
2001 Ford Excursion Limited 4x4 7.3L,V/B Spring Mod, ProComps, Hellwig Swaybar, & other 'Necessities'
golfmedik is offline   Reply With Quote
Old 04-01-2013, 04:08 PM   #16
ironj's Avatar
that sounds about in line for a set of firestones..seems like the air lifts are a little cheaper.....hence why i was curious about the guy who got em for 225 INSTALLED....and hour of shop labor is like 70$ minimum??
that viair is top of the line stuff....how much more did that set ya back?...i had dual viairs on my old 88chevy that was bagged.....never once an issue with them...
Old 04-01-2013, 04:22 PM   #17
golfmedik's Avatar
I love the Viair system. I bought it for around $350 or so a year ago and then bought the Firestone Dual Pneumatic guage and plumbed it all in so I can adjust on the fly. The guage alone was around $225 but makes the system worth the money. I did an install write up on it here http://www.forestriverforums.com/for...led-35846.html I did it all myself. Pretty fun mod!
Old 04-01-2013, 07:03 PM   #18
Lynkage's Avatar
I did the same Viair setup except I did not want to run air tubing all the way up to my dash and back, so I used some electric over air solenoid valves and SPDT switch and a 12V oil presure gauge (still looking for a cool digital gauge to integrate in my dash.)
Here is the album:
Forest River Forums - Lynkage's Album: Airbag Install
Shane & Antoinette
Old 04-01-2013, 07:24 PM   #19
jonnys_walkers's Avatar
Air Bags
Dave
Dave,
If you set them up that you inflate them individually it will take the body roll out of your vehicle. They are used for levelling, not to increase the Gross Vehicle Capacity of your tow vehicle.
On less than smooth driving surfaces it will enhance your ride.
I put rubber stoppers in to contact my overloads sooner to also enhance my ride.
I see Ride-Ride now has a rubber block inside their air bag that it prevents you from ever running flat in you air bag.
Never enough camping!!
jonnys_walkers is offline   Reply With Quote
Old 04-01-2013, 07:25 PM   #20
Scratch's Avatar
Yes. They installed a very nice onboard compressor & cab gage setup with on-the-fly capability to two bags. We use the heck out of it. Usually 35lbs when we pull and 5 lbs. or so when unhooked.
Scratch sends...
'14 nights camped:
