First Trip Issues
We took our first shakedown trip last weekend. We had a great time overall, pics to follow tonight. Now I have to deal with some issues. I hope some of you can shed some light for me. The first issue was a leaking sink in the bathroom. After a close look with water flowing, I found the leak is coming from the grey plastic pipe coming from the sink itself. The trap and seals were not leaking. My questions is, what type of material is this and what type of glue or sealant should I use to repair this leak?
The second issue is the lack of 120V AC power when I connected back to shore power at home. I connected as usual and noticed the fridge did not switch back from propane to electricity. I tried a 120V lamp also, no joy there either. I tried resetting the GFCI outlet in the bathroom, no light or resetting it. There were no breakers tripped at the converter. Is there something else I need to check, or is there a procedure to follow when connecting to shore power? I had no problems at the campsite. I just plugged in and turned on the breaker. Everything worked fine.
Thanks in advance for the assistance!
James and Karen
Warner Robins, GA
2011 Lacrosse 301RLS
2007 Tundra CM 5.7
Reese Dual Cam
