Old 05-08-2012, 01:31 PM   #1
First Wheel Bearing Regrease
I have a 2011 Lacrosse 301RLS. I am ready to service the wheel bearings. I purchased some red lithium-based #2 grease for the job. Should I remove the wheels and drums and hand pack the bearings or just remove the chrome center cap and pump some grease into the zirk fitting? Thanks!
James and Karen
Warner Robins, GA
2007 Tundra CM 5.7
Reese Dual Cam
jjarrard is offline   Reply With Quote
Old 05-08-2012, 02:27 PM   #2
I did a search on here for :wheel bearing service" and came up with this link:
http://www.forestriverforums.com/for...ures-9666.html
Lot of good info here, even some PDF axle manuals. Might want to do a little reading, before you proceed. Hope this helps to answer your question.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
