Old 10-01-2016, 07:50 PM   #1
Flickering LED lights
Hello all
We have a 2016 Crusader 297RSK.
It came standard with LED interior light.
Our last couple trips have been boon docking running our ac from 2 Honda eu2000 generators connected in parallel. ( I'm not sure if this only happens when on the generators. However I don't distinctly remember this flicking taking place at campgrounds while on shore power.)
We have come to notice that sporadically the LED's will flicker. They don't seem to shut off but seem to get brighter for a split second the go back to "normal". This happens for a short time then stops.
Not really sure what would cause this. I look forward to any insight anyone might have.
Thanks for the help
MRDEGOLD
mrdegold is offline   Reply With Quote
Old 10-01-2016, 08:09 PM   #2
It's your onboard charger/controller adjusting the charge rate for your house battery(s).
SidecarFlip is offline   Reply With Quote
Old 10-02-2016, 07:25 AM   #3
Thanks for the response SidecarFlip.
Is this normal? Does anything need to be looked at, adjusted or replaced?
Thanks again for the help
Old 10-02-2016, 08:09 AM   #4
Nothing of consequence. You'll notice when you disconnect your shore power and / or genny, the lights don't pulse. Because the controller isn't adjusting current anymore.
led, light
