Old 07-27-2012, 02:33 PM   #1
Floor Flex in 318BHS
Hello Everyone,
We are enjoying a week away and had a pleasent trip towing with our improved tow vehicle (See previous post). One thing we noticed on this trip is the floor flexing around the floor vent in front of the kitchen sink when stepping in that area. I was wondering if anyone else is experiencing this or is there a problem we need to look into. If I recall correctly the floor is also a laminated panel type and not the typical OSB flooring substrate, can someone verify this as well.
The last thing I want to do is start tearing into the floor if a certain amount of flex is normal.
HAARubicon is offline   Reply With Quote
Old 07-27-2012, 02:47 PM   #2
Dave_Monica's Avatar
If you were to remove the vent cover, could you see the floor's construction?
Dave
Old 07-27-2012, 03:14 PM   #3
All I can see is the duct work.
Old 07-30-2012, 08:58 AM   #4
Commercial Member
If your LaCrosse says "LUXURY LITE" on the outside, it is a laminated floor.
To some degree, all floors flex a little - particularly in the kitchen area where we would typically install a holding tank. A structural failure resulting in excessive flex is very unusual, but . . . if it seems to be excessive, we'd suggest having a dealer look at it just in case.
PTM
RV Guy is offline   Reply With Quote
Old 07-30-2012, 09:21 AM   #5
ironj's Avatar
I dont know how much yours are flexing, but i did notice on pdi that mine had a small ammount of give around the vent only.......i chalked it up to the vent and its associated hole in the floor?...it was not an ammount of flex that would make me think structural issue...kinda how the walls where the thermostat is mounted flex and bend when i push buttons on the a/c.......i dont like it, but i understand there has to be a balance between weight,cost, and FUNCTIONAL structural rigidity....but if yours seems excessive i would def get it looked at.
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 07-30-2012, 09:36 AM   #6
It is something that i can actually feel when i step in the area, and being in front of the kitchen we step there a lot. I was going to run down to the dealer and check one on the lot to see if it is similar, if not I will bring it in. I also noticed a bend in the side of duct work, I am not sure if it is a result of the flexing or just a sheet metal thing.
Old 07-30-2012, 10:12 AM   #7
ironj's Avatar
i dont feel any flexing when in the kitchen.....or at least none that have caught my attention while i was in there....so yours may in fact have an issue...either way, let us know what you find out if anything....
Old 07-31-2012, 02:34 PM   #8
I have noticed no flex in my floor as well...feels pretty solid
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
kozzy is offline   Reply With Quote
Old 09-20-2013, 09:34 AM   #9
HAARubicon, did you ever find out what the problem was? I just bought a 2013 318 BHS from an auction and im having the exact same problem. Id hate to tear into a brand new camper but I dont like showing off my TT and the first thing everyone notices is the soft floor around the vent in the kitchen. Thanks in advance!!!
dtaber8604 is offline   Reply With Quote
318bhs
