04-02-2014, 12:52 AM
#21
Must say that recall looks very odd ie units affected 26?? Was last modified in November but the recall date is march 2014. Resolution to be determined. No serial numbers or model??
2014 295rst TE Champagne
09 GMC 2500HD D/A
04-02-2014, 02:38 PM
#22
Called PT and confirmed my unit is not affected. They said it was a very small number. Best to email them your vin and ask. Dealer knew nothing. PT has the parts to correct from lippert. Involves raising trailer 1.5 inches and grinding off a metal edge.
09 GMC 2500HD D/A
04-02-2014, 02:41 PM
#23
Thanks for that information!! Will do that promptly and ask about that awning recall too 👍
04-02-2014, 03:14 PM
#24
Correct me if I'm wrong but with the awning motor there were two serial number series that were the bad ones. I read it in the awning thread it was serial #'s 306xxxx and 314xxxxxx that were the bad ones.
2021 Alpine 3790FK
2021 F-350 SD XLT PS 6.7 Dually Longbed 4wd Crew Cab
04-02-2014, 04:23 PM
#25
Jumped on the horn today and talked with factory. Mine unit has the recall for the slide out bracket rubbing the tire. They setup an appt with my svc dealer and sent parts and a new tire. Dropped rig off and will hopefully pickup tomorrow. They have been great so far! Will update with the fix status tomorrow. Thanks for this forum and bulletin as it prob saved me from a tire blowout Nd who knows what else.
04-02-2014, 04:24 PM
#26
What model do you have and when was it made? Were they able to verify all this with your VIN??
04-02-2014, 04:30 PM
#27
FOREST RIVER issued a recall on the CRUSADER model
Mine is a 315rst. Was the dinette slide. Contacted factory first and I supplied them pics. Never gave then my vin but they knew who I was and found me in computer system so they must have my vin somehow. Mine is a 2014 and mfg 10/14
My tire is scraped up pretty good and I've only take it out about 150 miles plus delivery to dealer from mfg.
04-03-2014, 10:26 AM
#28
Got email back just now from Roger at Prime Time to check our 325RES
Only affects 315 models
04-03-2014, 01:44 PM
#29
It was my understanding that it was not just 315 models but I'm not 100 percent sure. If I owned a crusader regardless I would be looking.
04-03-2014, 01:47 PM
#30
Roger at Prime Time stated it was only those 315 ....said our 325RES was not included - i sent an email at 1030 am today thru their website contact us and had an answer before noon 👍
04-03-2014, 02:11 PM
#31
That is good to know. I went out this am and slid under my 325 on a creeper just to make sure and all is good under there.
2021 Alpine 3790FK
04-03-2014, 03:08 PM
#32
Heard from Shane on mine re: this recall and the awning recall. My 295RST is not impacted.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
04-03-2014, 06:47 PM
#33
Todouble, let us know what they do to fix. Curious what parts they change to only lift the camper 1.5" if that is correct. I could use 1.5" to get level. Think an axle flip wpuld be topo much!
04-03-2014, 07:23 PM
#34
Well I gotta say prime time is outstanding! I contacted Shane about 1230 on wed. He responded back to my email in less than 30 mins and had me lined up with the dealer to fix. I explained I was going on a trip this weekend and he overnighted parts to my dealer and had it done today by 3 pm. Went and picked up today and brought home so we can head out in the morning. Between him and my dealer they all worked together brilliantly and got me done in about 24 hrs start to finish of my email. Shane even contacted me and gave me updates on the tracking of the parts. He took time out of his evening and was emailing me updates at 9 pm at night! You won't get that anywhere else! BIG SHOUTOUT to prime time and Shane!
As to the fix, they grind the sharp corner off and round it over. Replaced my tire and added a 1" lift per paperwork to unit. Not exactly how or where but it raises the back up an inch. In my case it was beneficial as I was a little nose high in the front and now I'm about level or close enough! I now have about 3 1/2-4" of clearance which should be more than plenty and in the rare case it does touch briefly it's a rounded corner so it shouldn't do any damage! Hope this helps guys. More questions let me know!
04-03-2014, 08:56 PM
#35
2014 Prime Time Sanibel 3250
04-04-2014, 08:45 AM
#36
Commercial Member
Greetings!
We will attempt to fill in some blanks for those interested:
The recall ONLY affects the Crusader 315RST with a VIN (last 6) between 114929 and 116011. Although this is a range of 1082 units, only a small portion of these units are the 315RST model.
The problem was identified and reported last week to US and Canadian authorities. Obviously, the Canadian authorities have published this info. I'm sure the proper US authorities will publish soon. The process dictates that we notify the proper authorities and then they provide us with a Service Advisory number that we have to use when contacting our customers.
Letters are being finalized today and will be sent to customers first thing next week.
Repair kits are here, boxed up, and being sent to dealers right now.
Please address any questions to Roger in our Customer Service department. His email is rstickel@forestriverinc.com
Hope this helps answer some questions.
PTM
04-05-2014, 05:34 PM
#37
Originally Posted by RV Guy
Greetings!
PTM
Once again PT doesn't leave us hanging very long. They identified, reported, have a solution, let us know and...... have repair kits on the way instead of waiting for a dealer to get one in and have to "order" the kit.
This is why I bought PT again when we decided to upgrade.
04-05-2014, 06:33 PM
#38
Hell they were so good Shane had me fixed at my dealer before they even sent out the letter! Prime time will
Have my business everytime if this keep up! Good job pt
