Old 04-01-2014, 10:21 AM   #1
Sgt. Schultz's Avatar
FOREST RIVER issued a recall on the CRUSADER model
FYI - Ran across this while looking up another recall --
FOREST RIVER issued a recall on the CRUSADER model - Recalls & alerts - Healthy Canadians Website
Starting date:March 24, 2014
Type of communication:Recall
Subcategory:Travel Trailer
Notification type:Safety
MfrSystem:Structure
Source of recall:Transport Canada
Identification number:2014091
TC ID number:2014091
On certain model fifth-wheel travel trailers, the tires may have inadequate clearance with the trailer slide-out actuator bracket and may be damaged while towing under certain road conditions. This could result in a blow out which could lead to a crash resulting in injury and/or property damage. Correction: To be determined. Owners are advised not to tow their trailers in the interim.
PT Avenger 33BHS-TE
2020 f-250
Sgt. Schultz is offline   Reply With Quote
Old 04-01-2014, 10:24 AM   #2
heavynlori's Avatar
Well WTH!?!?! 😱 How can we find out which ones are affected?
heavynlori is offline   Reply With Quote
Old 04-01-2014, 10:26 AM   #3
Todouble's Avatar
Subscribing! Would like to know more?
Todouble is offline   Reply With Quote
Old 04-01-2014, 11:03 AM   #4
Always Learning
Here is the Transport Canada database search results for Prime Time MFG:
Road Safety Recalls Database
Old 04-01-2014, 11:20 AM   #5
Awesome - a completely different issue identified there -- electric awnings for a whack load of models
PT Avenger 33BHS-TE
2020 f-250
Old 04-01-2014, 11:22 AM   #6
heavynlori's Avatar
I saw the awning recall already....
Old 04-01-2014, 11:24 AM   #7
heavynlori's Avatar
I think it was on here actually and gave the details on mfg date period affected
Old 04-01-2014, 12:12 PM   #8
For the Transport Canada Data base
If you run the search using Prime Time it does not show the recall that started the thread - it comes up with the awning one.
If you search ( Road Safety Recalls Database) using Forest River it is the first one on the list
The WildCat one from Jan 30 is scary as well "the Gross Vehicle Weight Rating (GVWR) indicated on the compliance label may exceed the combined load carrying capacity of the trailer axles as well as the trailer hitch pin box"
PT Avenger 33BHS-TE
2020 f-250
Old 04-01-2014, 12:39 PM   #9
B and B's Avatar
They also have a recall on 2012 2013 Rockwood/Flagstaff for axle clearance issues. Called my dealer and he is running my SN for my fifth wheel.
B
B and B
Old 04-01-2014, 12:46 PM   #10
Todouble's Avatar
Just went out to look at our crusader. Couch/dinnette slide looks like it's the only one. There's a bracket 1"-1 1/4" away from the top if the tire and it's on an angle so I imagine if your traveling along and hit a pothole and things bounce it will spear the top of your tire.
Name:	ImageUploadedByForest River Forums1396374368.307693.jpg
ID:	48931Click image for larger version
Name:	ImageUploadedByForest River Forums1396374380.326535.jpg
ID:	48932Click image for larger version
Name:	ImageUploadedByForest River Forums1396374390.074391.jpg
Name:	ImageUploadedByForest River Forums1396374349.619895.jpg
Old 04-01-2014, 01:35 PM   #11
DDC
DDC's Avatar
This is why it is important to report safety issues to your appropriate gov. organization, they do get things moving and the manufacturer has to fix things properly. Take a look at GM right now.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-01-2014, 01:50 PM   #12
Todouble's Avatar
It wouldn't be so bad if it was a rounded corner but it's thick metal with a 90 degree sharp edge on it. You hit a big enough bump at 60 mph that thing has to take a chunk out of the tire. Maybe time to get the grinder out and round that edge
I did check the awning recall but I'm not built in that time frame so good there!
Old 04-01-2014, 02:30 PM   #13
irishrv's Avatar
What is your model?
2014 295rst TE Champagne
09 GMC 2500HD D/A
irishrv is offline   Reply With Quote
Old 04-01-2014, 02:46 PM   #14
Todouble's Avatar
Originally Posted by irishrv View Post
What is your model?
315 rst
Old 04-01-2014, 03:09 PM   #15
LKicklight's Avatar
See nothing on our orphaned 270RET Model, she is a 2011 model, I will check it just the same..the photo that was posted does not leave a whole lot of room to work with:
kickster
2500HD 6.0 Gas/Ext. Cab
2011 Crusader 270RET
2003 Sunnybrook T/T 30FIS
2012 Jeep Compass Limited
1985 S-10 One Owner:
LKicklight is offline   Reply With Quote
Old 04-01-2014, 03:46 PM   #16
Todouble's Avatar
Yeah the more I look at the pic it looks like that corner tab should of been cut off. The point of it is about one inch from tire tread. Dangerous!
Old 04-01-2014, 04:18 PM   #17
irishrv's Avatar
Check mine and post back.
09 GMC 2500HD D/A
Old 04-01-2014, 04:39 PM   #18
Witch Doctor's Avatar
B
B&B what model do you own and are you on the list? My Rockwood is 2012. I guess people have been adding lift kits for certain units I know I have about 3 fingers clearance between the wheel and wheel well. If you are in a recall. I thought that you had to be notified of the recall?.......
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-01-2014, 05:57 PM   #19
We have to rely upon the Transport Canadian database? --- where is the notification for the US owners? How do they notify and when ?
Dave & Barbara Harris
2021 2506S
2018 Grand Design Imagine TT 2250RK
2013 Prime Crusader 5th Wheel 290RL
2006 Glendale Titanium 5th wheel 30E35TS
2015 GMC Sierra Z-71, 1500, std bed, 4 WD, 5.3, 3.42
camperdave825 is offline   Reply With Quote
Old 04-01-2014, 09:23 PM   #20
irishrv's Avatar
Shot from under my kitchen slide. Not seeing muchClick image for larger version
Name:	ImageUploadedByForest River Forums1396405418.015458.jpg
09 GMC 2500HD D/A
crusader, forest river, recall, modifications
