Originally Posted by JohnD10
Either you had another issue or would have been better off to put the check valve in front of the pump instead of after it.
Did you check the screen to see if it was clogged?
Hi JohnD10, there was no other issue, when the valve was removed pump performance returned to normal. Mechanical engineers handbooks will advise never install accessories in the the pump suction, it may lead to pump starvation and damage. My pump was mounted above the fresh water tank, suction head was at a premium. The pump internalnon return valve is a small diameter nylon ball never shown on drawings. It fowls easily and easily cleared as outlined in an earlier post, that’s how I solved the overflow problem. Keep the tank one level below full and push the button when you happen by.
