Old 08-15-2013, 07:31 PM   #11
RollingDownTheHighway's Avatar
the fridge outlet isn't even a GFI, there's only one plug for it actually.
2013 Prime Time Tracer 3200BHT
2016 Chevy 3500 CC, DRW (aka: bigbootyjudy)
Ribs in the smoker and Whiskey in hand
RollingDownTheHighway is offline   Reply With Quote
Old 08-15-2013, 07:32 PM   #12
Originally Posted by Acableguy06 View Post
Is this a 50 amp or 30 amp unit?
30amp,
Old 08-15-2013, 07:39 PM   #13
This outlet comes straight from the breaker box?
There could be a gfci upstream from this that could be tripped. I would double check them all.
I was asking about the 30 or 50 amp because of how they are wired, but since its a 30 there should be no configuration issues.
The next thing to do depending on how handy you are is pulling the plug out and checking the wiring. But being its new I would be contacting the dealer if you are not electrical handy.
Acableguy06 is offline   Reply With Quote
Old 08-15-2013, 07:44 PM   #14
Fuses? The fridge 120 outlet should be on a breaker, not a fuse. Turn that breaker off and then back on again. It's not always possible to tell when they are tripped.
Old 08-15-2013, 07:48 PM   #15
I reset the breaker, I unplugged the camper from the house even, kind of 'reset' it all. I'll call the dealer tomorrow to take it up but we're going camping for a week starting tomorrow. If I run it in propane the entire time will that cause any issues? I have an outside working fridge if needed
Old 08-15-2013, 07:48 PM   #16
Batts-toy's Avatar
there's no power, the kitchen fuse is fine, is there a seperate one for the fridge? the only thing I see for the fridge is the breaker and that's not tripped
They definitly are in the habit of sharing breakers. My frig outside plug is shared with the same circuit as the television/entertainment center plug. This 110 volt breaker also has an additional wire going I do not know where.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 08-15-2013, 07:51 PM   #17
Batts-toy's Avatar
Are your breakers labeled? If you have a volt test meter I would test for current at the breakers to see if one is without power, it could be tripped but not obvious to the eye or the breaker itseft could be defective.
Old 08-15-2013, 07:53 PM   #18
Batts-toy's Avatar
No issue with staying on propane just paying for propane is all.
Old 08-15-2013, 07:55 PM   #19
Brother Les's Avatar
Has your fridge worked on 110 in the past or could you have thought it was and really been running on propane? Go to the fuse panel and look at the 'breakers' and see what each is labeled at. AC, Micro wave, Plugs? are any 'popped'? Go through each one and trip on and off. I have seen some RVs that have a 'on/off' switch for the fridge plug, can you see where the wire goes and is there a switch. Have you tried both plugs as one may work and the other may not. Is your trailer still under warranty and have you called the dealer. Do all of your electrical plugs in the camper work. there may be one that is in line with the fridge plug and it may not work. If you are comfertable to check the connections at the converter, shut the power off and check all connections of + and - .
Safety first and always.
Brother Les
Old 08-15-2013, 07:59 PM   #20
Batts-toy's Avatar
This is not a computer powering down and back up did not reset anything the effected breaker has to be turned off all the way back to the reset position then back on.
Not trying to be an a** just saying this to be of some help.
fridge
