Old 11-22-2014, 11:57 AM   #1
MrNiceGuy's Avatar
Furnace Crusader 315RST
I'm in the process of putting together a list of amperage loads for the appliances in our 2015 Crusader 315RST. I'd like to put in a 6 volt battery bank in the spring so I'm trying to do my homework over the winter months. The manual that came with the unit is a generic Atwood furnace manual that lists all models under the 8500-iv furnace. Our unit is in stoage for the winter so getting to the furnace is going to be a bit of a problem. Does anyone have a similar unit that can help. Thank you!
Jim
2011 Silverado 2500HD 4WD 6.0L/4.10
2015 Prime Time Crusader 315RST
2005 Cairn Terrier
MrNiceGuy is offline   Reply With Quote
Old 11-25-2014, 06:34 PM   #2
Todouble's Avatar
From what I remember on mine it's a 30k btu heater. Pretty std in most 5th wheels this size. I'm not sure of the amp draw from it, mines currently at the dealer so I can't help to much
Todouble is offline   Reply With Quote
Old 11-25-2014, 07:12 PM   #3
MrNiceGuy's Avatar
Thanks for the info. I think I'll be able to get the specs off the furnace later this week. I want ot check on the camper as we're expecting a pretty good snow storm tomorrow.
Old 12-05-2014, 11:20 AM   #4
electroblast's Avatar
Hi Jim,
I own a 325RES, and I did check the amount of current the furnace was drawing, at start it draw 8 amps for about 3 sec. then stabilise at 6 amps all on the 12V battries That is the FAN in the furnace drawing that much current.
I haven't chech the model of my furnace, but it's probably similar.
Jean
electroblast is offline   Reply With Quote
Old 12-05-2014, 03:28 PM   #5
MrNiceGuy's Avatar
Jean,
This is exactly what I was looking for. Thank you for taking the time to help me!
Jim
crusader, furnace
