Old 07-23-2012, 08:13 AM   #1
Furnace issue
Our first issue with our 1year + Crusader. Tried to fire up the furnace this weekend and the blower would come on and then I could hear the igniter fire and the main burner light. The main burner would then shut back off. It wouldn't shut down immediately but would taper off over about 1/4 to 1/2 a second, like it was burning gas left in the line. Wondering if anyone else has had an issue like this. It seems like a gas delivery issue as i would expect a bad thermocouple to shut the burner down immediately and not taper off? any thoughts?
2004 GMC Sierra 2500
2012 Primetime Crusader 298BHD
sbelliott is offline   Reply With Quote
Old 07-23-2012, 08:23 AM   #2
trudinator's Avatar
Furnace? Really??? It's supposed to be 98 degrees here today with a heat index of 106. SO wish we had furnace weather.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 07-23-2012, 09:11 AM   #3
About 10,000 ft high in the Bighorn mountains gets a little chilly at night. 56 degrees saturday night.
Old 07-23-2012, 09:16 AM   #4
TURBS's Avatar
Try shutting off propane tanks and waiting a few seconds then turn them on very very slowly.
Might also be a little air in the line.
Old 07-23-2012, 09:27 AM   #5
Thanks, I will try that. I just so happens that I just filled my RH tank a week ago. First time I have filled propane since I bought the camper. The LP switching device was making some noise when the furnace burner woudl first kick in? water heater and other stuff seems to work fine but I think the furnace gas usage rate is a lto higher than anything else?
Old 07-23-2012, 09:47 AM   #6
TURBS's Avatar
That's what I'm guessing.
Try the valve closing trick.
Ron
Old 07-23-2012, 08:52 PM   #7
rracer5's Avatar
Check the air venturie (sp). Sometimes spiders and other critters build webs and/or just interfere with the air flow which results in an inefficient burn. Enough blockage and the flame could just go out. I had to clean a nest of stink bugs out this spring. It was easy after they were fried and crispy. Then I just blew them out with a little compressed air in a can.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
