04-08-2012, 06:11 PM
Furnace operation on a tracer 2800rld
Hello folks. Camping this weekend we used our furnace for the first time. I think it may not be operating correctly. When you put the thermostat on the desired temperature, the fan 1st kicks on, and then shortly later you hear the furnace start. Air blows from the registers in the floor, but also the big air vent in the ceiling which I believe this is the air conditioner. This vent I believe is part of the air conditioner. Is this correct, should it vent fron the ceiling vent? Also when the heat is on, you hear the furnace kick off when the proper temp is reached, but the fan does NOT kick off. The fan never turns off, it runs as long as the thermostat is set to furnace. Should not the fan stop? On our old camper it did. Also the thermostat is very basic. It is digital but can it be replaced with a better one like you would use at home, our do you have to buy one made just for a camper? Thanks for any help. Bob
[SIGPIC] 2102 Tracer 2800rld, 2012 Chevrolet Silverado 2500HD, crew cab, 3.73 gears, 6 sp Transmission
04-08-2012, 06:35 PM
Is the "fan" set to "ON"?
I think there might be an "auto" setting.
In our Flagstaff we have a manual thermostat so I will be of little help.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-08-2012, 06:39 PM
Sounds like the thermostat may be wired incorrectly or maybe two wires are touching that shouldn't be. Would check that first. What kind of thermostat is it? Picture of thermostat & wires would be helpful.
04-08-2012, 07:14 PM
Jack of All Trades
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
04-08-2012, 07:22 PM
Use the On/Off Mode button to select FAN. Then use the +/- button to select either Hi, Lo or Auto. When using the AC and the fan is in the Hi or Lo setting it will run continuously while the compressor will cycle on and off. In the Auto mode the fan will cycle on and off as well.
If the fan is set on Hi or Lo while using the furnace, the AC fan will run continuously, so be sure to set the fan on Auto when using the furnace. You can, however, leave the AC fan running while using the furnace to help with condensation problems.
After setting the fan, Use the On/Off Mode button to select COOL for AC use. Use the +/- button to select the thermostat temperature setting. Use the same procedures for the furnace.
When using the AC, in the Auto mode the fan will run on high when the room temperature is 5º or higher than the thermostat setting. When the room temperature drops to within 4º or less than the thermostat setting, the fan will stop for a few seconds the start again in the Lo mode.
Hope this helps.
04-09-2012, 07:54 PM
Yes...need to set the fan to auto and close the vent in the ceiling unit
I've been called SMART many times....but it's always followed by ASS for some reason!!
04-11-2012, 06:17 PM
I solved the problem of the ac fan blowing when the heat on. The dometic lcd thermostat must be set on AU, not hi or lo. If on hi or lo the ac fan will run when the heat is on. Thanks Bob
10-28-2012, 07:25 AM
It works...Set the fan to auto and problem solved. Much appreciated everyone. Seemed counterproductive to have the furnace and the fan running at the same time.
