Old 01-28-2015, 06:41 AM   #1
BBBlue's Avatar
Furnace Preventative Maintenance
I have been accomplishing the preventative maintenance on my 2013 Sanibel 3500 and have a question as to what others are doing for preventative maintenance on the furnace. I vacuum all ducts as far as I can access with a vacuum cleaner. I pulled the wall in the storage compartment and cleaned all the dust around the area and check all supports. I cannot find access to the burner, ignition components, or combustion chamber. I have check all access points from the storage compartment and under the stairs. Anyone out there have any info on this?? Furnace is operating properly and I don't notice any soot buildup at the exhaust port on the side of the 5th wheel.
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is online now   Reply With Quote
Old 01-28-2015, 06:56 AM   #2
KyDan's Avatar
If you don't already have it- install bug screens on the outside exhaust vent
and forget it!
Sounds like you're good to me!
Peace!
Dan & Rita D
Blue Ox WD hitch
furnace, maintenance, vent
