Old 10-08-2013, 01:33 PM   #11
zs325RES's Avatar
UDS winterizing access made simple
I got tired of taking those 4 screws out and putting them back in, so I mounted the basement access panel with a hinge and thumb screw release.
Works great - no tools.
Going into storage today.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 10-15-2013, 05:50 PM   #12
How does the winterizing with "air" work? Is there some sort of adapter needed to hook up an airline to pressurize the water system? Via the "city water" connection, I guess? This does sound preferable to filling the system with antifreeze.
OakHillFarm is offline   Reply With Quote
Old 10-15-2013, 10:52 PM   #13
Anacortesians
Did ours today - drained the water heater, blew out all the lines with the air compressor (including the toilet and the outside shower). Tomorrow, I put the oil-filled radiator in the corridor between the toilet and the master bedroom and set it up with the thermostat.
I have a digital plug-in thermostat and hook it up through a Kill-a Watt meter, so I can see how much power I burn to keep the living area above freezing. I also have an indoor/outdoor temperature gauge. I leave the "outdoor" transducer inside the RV and have the 'indoor" display in the den. I can keep tabs on how cold the RV interior gets.
Last season, the Kill-o-watt meter showed we'd used about 20 KW hrs keeping the interior above freezing for three months, I think that's a small price to pay to be sure nothing in the rig's interior will freeze. The inside temperature gauge never went below 38F despite several days with ambient temps in the 20's overnight. Daytime highs below about 38 are very rare here, which is one of the reasons we live here!
Frank and Eileen
No longer RVers or FR owners
Old 10-15-2013, 10:58 PM   #14
Ford Idaho's Avatar
You need one of these.
Camco Blow Out Plug
And something like this.
1 4" NPT Brass Air Chuck with Clip Ball Tire Inflator Home Business Automotive | eBay
Old 10-16-2013, 06:23 PM   #15
Ford Idaho - Thanks for the information. I think this looks preferable to the whole antifreeze in the water lines scenario. I also like the suggestion above regarding the oil filled radiator to safely and cheaply maintain a little heat in the unit over the winter. Mine will be stored inside my pole barn so it does not get quite as cold as sitting outside so I think this combination should work.
In years past the barn has stayed warm enough overnight to melt most of the snow off of my truck so it should be fairly easy to keep the camper above freezing.
Old 10-16-2013, 06:41 PM   #16
Ford Idaho's Avatar
You are welcome, but I can not take credit for the idea.
I do like the air chuck that I posted because it will lock on to the valve stem making it a one person job.
If you go this route be sure to use only 30-35 PSI output from your air compressor.
Old 11-01-2013, 08:52 AM   #17
heavynlori's Avatar
Winterizing our 2014 Crusader 325RES
We also just recently winterized our rig. I had to crawl into the storage compartment and could barely reach the bypass valves in the inconvenient location!!
FYI - a quick look at the dealer website where we got our unit showed several 2014 models on the lot and when you look at the pictures of those units, several of the NEW 2014 models have the improved water heater bypass system clearly shown in the docking center!!! How aggravating to know that some of the early 2014 models were put together with the rotten set up and then they changed production on the next ones.....
Oh well, we still like the rig and are looking forward to next camping season already - counting the days till April 1, 2014
heavynlori is offline   Reply With Quote
Old 11-02-2013, 09:59 AM   #18
wmcclay's Avatar
I am so glad I live in a area where I do not have to winterize. Can use it year around, but I do have to put up with California.
Wayne and Donna
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 11-05-2013, 08:26 AM   #19
heavynlori's Avatar
winterizing 325RES
We have an earlier 2014 version of the 325RES with the unhandy winterizing valves located on the backside of the water heater that cannot be reached unless you crawl into the storage compartment....
NOW the recent 2014 325RES have a winterizing bypass setup at the docking station - guess we should have waited to buy a month later....pictures are showing up on dealer websites
Old 11-05-2013, 08:36 AM   #20
Fulltime family RVer
There will always be something newer and better. When the 2015s start coming out, there will be little changes that you wish you had. And when the later 2015s come out, there will be more tweaks.
I hear your frustration- but I can honestly say that I appreciate it from Forest River. They listen to us and our complaints and try to address them. I sent a list of 18 things to Sabre and I can honestly say, the newer models of my camper have a good 15 of them either standard or as options.
winter, winterize
