Old 05-30-2018, 12:35 PM   #1
Groound Control 2.0 Rear sensor
Does anyone know where Prime Time places the rear sensor for the lci ground control autoleveing. I have a 2014 Crusader 290rl. It is under the belly of the unit under the plastic. I am getting sensor error messages and the fix seems to be as simple as checking the connection. I can cut through the underbelly plastic and patch the plastic rather than drooping the whole thing, just wanted a good guess as where to start. The problem comes and goes so it does seem like a bad connection some where. I have tried the connector in the front storage area. No luck it must be by the sender unit.
Does anyone know how to bypass the sensor? When the problem pops up, it takes forever to raise or lower.
Robert
rscconrad is offline   Reply With Quote
Old 05-30-2018, 01:11 PM   #2
ben31's Avatar
The only thing I could find, which referenced the location is:
This sensor needs to be positioned precisely between the rear jacks so if you check midway between them this is the area where you should find the sensor.
I have a Crusader and would love to know the location, when you do find it. The only thing is the rear jacks are offset on mine, so wonder if it is still precisely in between them.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 06-13-2018, 05:47 PM   #3
For the archieves, I just fixed it. It is located dead center of the camper, right between the rear jacks.
It is not above the axle.
Unplugged and replied the connector and all is good
Old 06-18-2018, 12:03 PM   #4
ben31's Avatar
Thanks for the follow-up! I, like you, would rather not cut willy-nilly, if I don't have to!
Ben and Doreen
roo
