05-08-2012, 07:06 AM
Hail damage or is this ok rv guy?
We had a bad hail storm 10 days ago. Some minor damage, maxx air vents broken, spare tire cover damaged, awning fabric damaged and when I went on the roof, The rubber membrane had what I would call bubbles in 8 or 10 spots. It looked like the membrane was no longer glued to the underlayment, and bubbled up maybe a 1/8 of an inch. Is this normal or should I be worried? Thanks Bob
[SIGPIC] 2102 Tracer 2800rld, 2012 Chevrolet Silverado 2500HD, crew cab, 3.73 gears, 6 sp Transmission
05-08-2012, 07:12 AM
Just courious how was the awning fabric damaged?
man that hail sucks!
Got my truck to camper was fine. Whew!
05-08-2012, 07:20 AM
We also had hail. My trailer is mostly under a metal shed but the nose sticks out
about 2 feet. I went on top and found bulls eye marks in the caulking that goes
all across the front of the roof membrane. The joint where the roof meets the front
fiberglass. No marks I could see in the fiberglass. The caulk looked OK just dented
but I put some more on top of the dents. Also found both corner trim strips broken
on top. This is the little removable strip that covers the screw heads on the corners.
It begins at the top and runs all the way down the side to the bottom front and rear
corners. I just caulked the holes in this trim strip as it cannot be seen from the ground.
I also found a broken front clearance light-- check yours carefully. Also check
tail lights!!
As far as the roof membrane goes, mine looks OK. If I were you, I'd keep an eye
on yours and watch for future cracking where you now see those "bubbles".
Most roof membranes are not completely glued down. A few spots usually seem slightly
loose to me. I've not had a problem yet.
OTOH, if you're thinking of making a claim on insurance I'd for sure want a
reputable dealers opinion on the roof membrane!
I think the guys over at Louisville RV on Outerloop are pretty good. Why not
ask them?
Peace!
Dan & Rita D
05-08-2012, 09:05 AM
Not sure what your bubbles are, but since you have them and were in a hail storm I would recommend having the roof looked at. Hail will cause premature roof failure and it is hard to see, the hail will create little cuts in the membrane.
2019 Chevy 3500 4x4 Crew Duramax
2021 Wolf Pack Toy Hauler
2019 Street Glide
2023 Road Glide ST
05-08-2012, 04:57 PM
awning damage
The damage is where it is rolled up next to the side wall at the top. So the holes are next to the sidewall.
05-08-2012, 06:45 PM
Now a "Top Member"
Originally Posted by donald1945
I want to install an awning on the slide out but can't find any info on where to install the hardware as i'm afraid to damage the trailer. HELP!
Donald...first, WELCOME to the site. Now, since this thread is about hail damage, and started by someone else, you should start your own thread for this. It won't get lost in this thread, and will very likely get seen by a lot more people.
qepv...I would have your insurance company come out and have a look. They would likely be able to tell and get you the help you need.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
05-11-2012, 10:21 AM
Commercial Member
Bob - I'm not sure if you sent in the recent inquiry to our Customer Service group on small bubbles or not but if you didn't, I'd suggest sending some pics into our guys to take a look. Try this email - rstickel@forestriverinc.com - Roger is our Retail Manager and would be happy to help.
In general, its not unusual to have small bubbles and minor lifting particularly at the seams and rarely is this cause for concern. However, the hail could affect your roof and having someone take a look on site might be advisable.
PTM
05-11-2012, 10:39 AM
If you do make an insurance claim they will tell you to get an estimate of the repair of damages. So you might want to go ahead and do that as well. Just a heads up.
2012 Coachmen Catalina Deluxe Edition 28DDS
2002 Cadillac Escalade
