Old 12-19-2017, 05:37 PM   #1
Hard To Unplug
My new 50 amp twist lock cord is difficult to pull out of the RV. It goes on smoothly but unplugging after the counterclockwise twist requires a hard tug. Is this common? The cord is actually an adapter to 30 amp.
volwing1 is offline   Reply With Quote
Old 12-19-2017, 05:40 PM   #2
BandJCarm's Avatar
Dunno how common.......but I do have to wiggle mine out a little bit sometimes.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 12-20-2017, 08:33 AM   #3
SeaDog's Avatar
I would rather it pull hard then come out easy. Hard implies thighs contacts where easy would be just the opposite. My power cord also has to be wiggled to be removed.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
Old 12-20-2017, 09:08 AM   #4
Does you factory shore power cord fit the same?
Is the 50-30 adapter cord homemade?
Do you notice any damage to the spades?
A tight fit is good but bent spades or inexpensive aftermarket plugs are not.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 12-20-2017, 10:08 AM   #5
Broken Toe
Cowracer's Avatar
Do you always unplug with the breaker off? NEVER NEVER NEVER plug or unplug with the power on at the plug. Especially unplugging with a load on. You will cause an arc that will erode your stabs (the metal plug prongs). This will make it hard to plug/unplug and can cause heating that can create further problems.
Look at you plug stabs. if they look 'bubbly', melty or have little round balls on the end, you had an arc and you should clean them up with a small file.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
"Camper" 2016
Rockwood Signature Ultralite 8329ss
"Casper" 2017 Ram 2500 Laramie Diesel
..ProPride 3P Hitch - "Yeah. It's worth it."
Cowracer is offline   Reply With Quote
Old 12-20-2017, 10:46 AM   #6
Mine does that as well, I use some die-electric grease on my plugs, it helps with the connecting and dis-connecting the plugs, it also prevents corrosion on the plugs.
wildcatter is offline   Reply With Quote
Old 12-20-2017, 01:32 PM   #7
Hard to unplug
X2 on what Wildcatter said
South Bend Indiana
Rockwood, 2015 Ultra V 2715vs
05 gmc 2500HD Duramax/Allison
Happy Camper 2715 is offline   Reply With Quote
Old 12-22-2017, 10:03 AM   #8
The original cord is tight but not too difficult to unplug. I applied a dab of dielectric lube to the new adapter. Glad to report it now unplugs ok. Thanks for all your input.
