Old 11-03-2013, 08:52 PM   #1
dlavas's Avatar
Help please
We are new to the rv world! I have a 2014 primetime lacrosse 318bhs! Do I need to dump hot water heater after every trip? What are the low point valves for? Thanks for your help!
dlavas is offline   Reply With Quote
Old 11-03-2013, 09:06 PM   #2
davidjb's Avatar
no, only have to dump in freezing weather
davidjb is offline   Reply With Quote
Old 11-03-2013, 09:13 PM   #3
dlavas's Avatar
Thank you
Old 11-03-2013, 09:17 PM   #4
Denver, CO
garbonz's Avatar
Hot water heater needs to be emptied for winterizing, although emptying and flushing occasionally doesn't hurt.
The low point drains are to remove water from the lowest part of the piping with antifreeze or by blowing out during winterizing.
There are post here on winterizing, but things vary a bit depending on the unit you have.
2017 Fuse 23T
