Old 11-24-2014, 11:52 AM   #1
Help - Water Heater Bypass 290RLT
We are de-winterizing and can't locate the water heater bypass valves. We would love some hot water. Stuck in Louisville KY with wind gusts to 40 mph. Thanks for any help.
portliz is offline   Reply With Quote
Old 11-24-2014, 11:59 AM   #2
TURBS's Avatar
Directly "behind" water heater.
They "may" have to be accessed via a panel from the inside.
TURBS.
Old 11-24-2014, 02:43 PM   #3
on_the_bayou
PrimeTime's Avatar
Open the basement cargo door on the driver side of the RV. You will need to remove the panel behind the water connections. The valves will not be easy to reach. There is not an access from the inside.
2012 Crusader 290RLT
2012 Silverado 2500 Duramax (175,000 mi)
Camping:
2012: 4564 mi 31 days - 2013: 6277 mi 38 days
2014: 5146 mi 38 days - 2015: 1200 mi 9 days
2016: 342 mi 2 days - 2017: 2734 mi 22 days
PrimeTime is offline   Reply With Quote
Old 11-24-2014, 02:46 PM   #4
heavynlori's Avatar
Prime Time is correct ^^^^ on that information
I have to climb in ours to reach it BARELY with my short female arm !! Not enough room in there for DH to climb in there so I get that task !!!
They have since changed to putting it inside the docking center now but ours was an early 2014 before they finally changed it 😉
heavynlori is offline   Reply With Quote
Old 11-25-2014, 09:34 PM   #5
Thanks everyone. Found the valves. You are right one needs to hire a small child to get to anything back there. What were they thinking??? Oops guess they weren't.
Old 11-26-2014, 12:15 PM   #6
another_newfie's Avatar
Ours is in the same place on our 2014 295RST. I winterize and de-winterize about 10 to 15 times per year (we use our water system when winter camping), and it is a bit of a stretch to reach them, but once you get used to it, it's not all that bad. I am going to trim the luan wall back a bit to make access easier.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 12-04-2014, 09:37 AM   #7
Has anyone installed 12v solenoid valves replacing the 3 manual valves?
volwing1 is offline   Reply With Quote
Old 12-04-2014, 10:50 AM   #8
Witch Doctor's Avatar
That's interesting. But wouldn't you need 3 valves? I guess two could be on 1 switch but the bypass would have to be on it's own, Am I correct on that?
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 12-04-2014, 01:46 PM   #9
My post does not say 2 valves. It states 3.
Old 12-04-2014, 02:30 PM   #10
Your right I misread that.
Coachmen M/H
Concord
2018 / 300 DSC
290rlt, bypass, heater, water, water heater
