Old 04-05-2017, 09:00 AM   #21
NMWildcat's Avatar
Originally Posted by bob caldwell View Post
True story with Pullright auto slider
These type hitches require a capture plate that fits the pin box and activates the auto feature of hitch
Zowie, learn something every day. Thanks Bob. Sounds like it was engineered by someone who never had to use it.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 04-05-2017, 09:02 AM   #22
Left Coast
Hasn't caused me any problems yet, but it is heavy......If one takes the hitch head off, then the rest isn't all that bad
Old 04-05-2017, 09:44 AM   #23
Professional Curmudgeon
wrvond's Avatar
This is absolutely correct. However, it's only an issue if you pull more than one fiver. If the pin boxes are the same dimensions, it isn't hard to move the capture plate between units, either.
Note that the capture plate is just a plate that holds a wedge shaped hunk of metal. One could easily weld a wedge directly to the pin box and achieve the same thing if they wanted.
2022 Cougar Half Ton 24RDS fifth wheel
2014 Coachmen Catalina 253RKS (sold)
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 04-05-2017, 09:47 AM   #24
NMWildcat's Avatar
Thanks for the info! I'll just stick to my sidewinder that doesn't have any limiting factors
hitch
