03-12-2017, 02:36 PM
Home Faucets in an RV
Can you buy any home faucet to use in an RV? I need to replace the Galley one and looking at Bathroom faucet as well?
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
03-12-2017, 02:39 PM
Yes if spacing matches. A nice home one would not be as cheaply made. Replaced my kitchen one in my old camper a few years ago.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
03-12-2017, 02:40 PM
99% of RV faucets are plastic painted chrome color.
They all break and leak. Get a good one.
FROG AR-0019-242
03-12-2017, 04:45 PM
Have done it in ours...was a quick fix, and the home faucet is much nicer...no more squeaky plastic faucet.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
03-12-2017, 04:58 PM
Replaced the island faucet after the cheap plastic handle broke off. Went with one that has a sprayer. Bought at Lowes. Recently purchased a bathroom faucet which I'll install once I uncover the camper.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
03-12-2017, 05:09 PM
Yes I did the kitchen and bathroom.
No more flimsy plastic crap.
And Shower
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
03-12-2017, 05:29 PM
RV faucets are typically the same as home type as far as installation spacing goes. Kitchen faucets are either a single hole or 8 inch on center. Bathrooms are typically 4 inch on center. I have found all my RV's to comply with this standard. Of course, there will always be the exception.
03-12-2017, 05:32 PM
Yes. Do it. You won't regret it.
2015 FR3 30DS Motorhome
2017 PrimeTime Crusader 315RST 5th Wheel
2002 Thor Chateau Sport Class C
Good SAM # 807510227
FROG # GA-0056-236
FMCA # F471293
03-12-2017, 05:43 PM
And Shower
Nice was it hard to do I have not even looked yet but I think I will need a apex Crimping tool? Or do they use some other sort of connections
03-12-2017, 05:55 PM
World Wide Wanderer
Typically the connection to the faucet is a threaded connector. The only reason you would need a crimping tool is if you have to extend water lines for some reason. I haven't looked at mine to see if the threaded fittings are crimped on the pex or if they used an extension line of some sort.
I was looking at replacement faucets at Lowe's the other day, they are getting just as cheap as the stuff they put in RV's Several of the ones I looked at were plated plastic and they are still charging pretty high prices for them. Shop carefully.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
03-12-2017, 05:57 PM
And Shower
I like that showerhead! I was thinking about doing that last year. Nice job!
'16 Cherokee Grey Wolf 26DBH
'13 Silverado 2500 HD - 6.0 Vortec / 3.73
Equilizer WDH
Goodyear Endurance Tires
03-12-2017, 06:22 PM
Changed the bath to a Single lever model,changed the Plastic kitchen pull out to dual lever hi rise with threaded end for a Pur water filter! Buy at HD,let your pocket book be your guide,just like your Home! Youroo!!
03-12-2017, 06:30 PM
Kitchen was easier due to more room.
This is what it looks like after removal of the OEM faucet.
I cut my pipes to connect the new fittings, when in fact I didn't need to. They would have just threaded right on.
Under the sink with OEM faucet in place before removal. If I had smaller hands, I could have undone the connectors.
03-12-2017, 08:40 PM
Easiest way to work with the piping for sinks is cut the line install your faucet set then cut you a pice of pex or pvc pipe and use shark bites to put both together
03-13-2017, 08:55 AM
Yes...if you can't simply screw the lines back onto new fixture due to length od piping then the Shark Bites readily available in the plumbing section work great, and are quick and simple.
03-13-2017, 09:00 AM
I have the same shower in my Crusader and same showerhead. Did you put just one screw in and use Double face tape to hold it up?
03-13-2017, 12:23 PM
I have residential faucets with pull outs on both my galley and bathroom sinks. the faucet in the shower is still an RV unit however.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-13-2017, 12:40 PM
Nurek,
What type of head is that?
Where did you get the head house and mount?
03-13-2017, 12:43 PM
And Shower
nurek,
What type of shower head is that?
Where did you get the head house and mount from?
03-13-2017, 02:02 PM
Bob, that's an Oxygenics Body Spa shower head, one of the most popular RV upgrades out there.
