Old 07-29-2017, 04:52 AM   #1
071567's Avatar
Hot water
I have a Prime Time Crusader lite 34mb, and I can either use the gas water heater
or electric. That's gas water heater works fine ,but when I flip the switch on the control panel for electric hot water nothing happens. How long does it take to warm the water if you want to use the electric water heater.
071567 is offline   Reply With Quote
Old 07-29-2017, 05:05 AM   #2
Hot water
I have a 2017 Sanibel with that same opinion in my panel. Within 20 minutes If not less I have warm to hot water.
2017 Sanibel 3601
2015 F350 - 6.7 Diesel
Retired SMsgt USAF 21 years
6 years weekend camping Class C
2017 camping 20 days and counting
Brand2328 is offline   Reply With Quote
Old 07-29-2017, 05:24 AM   #3
Head Rambler
Sounds like you may have a bad electric element.
Which water heater do you have?
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 07-29-2017, 05:34 AM   #4
071567's Avatar
I have no idea, sorry
Old 07-29-2017, 05:53 AM   #5
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
Make sure the switch on the outside of the water heater (if you have it) is turned on.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 97
rjshiflet is offline   Reply With Quote
Old 07-29-2017, 06:23 AM   #6
BandJCarm's Avatar
I don't have a switch on the control panel for the electric part of water heater.
Can you post a pic of that switch??
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-29-2017, 07:24 AM   #7
Gumpster808's Avatar
Not sure if your specific model but ours is propane only. No switch on the water heater and the one inside just turns on or off for making via propane.
Lynn & Dennis
Nights Camped 2017 - 35 / 2018 - 15
2014 3051S - First RV for us
2018 Hyundai Elantra Sport Toad
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
Old 07-29-2017, 09:29 AM   #8
You should get hot water pretty quick. We had the same problem with our Crusader 297RSK when we first got it. The electrical connection was not made to the on off switch on the panel. Didn't think to question why the hot water was running on propane at PDI. The service department knew it wasn't working when they delivered our camper☹ shame on us for not checking. Had it fixed in the fall when we had some other warranty work done.
DwarfDogWalker is offline   Reply With Quote
Old 07-29-2017, 09:49 AM   #9
wmtire's Avatar
If you possibly have the Suburban SWDEL model water heater, there is a second switch for the electric heating element on the face of the water heater. Both switches have to be ON for the electric heating element to work.
It's explained in the following link, along with the SWDE model, which only has the electric heating element switch on the face of the water heater (no inside electric element switch like the SWDEL model)
Suburban's electric switch and much more
We have also seen many RV's sold that simply do not have the water heater plugged/wired in to a 120 volt outlet. You may need to access behind your water heater and make sure it is plugged in. If not, your gas side will work since it's 12 volt DC, but your 120 volt AC electric heating element will not..... which is another thing. You must be connected to a form of 120 volt AC power for your electric heating element to work.
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 07-29-2017, 10:20 AM   #10
Marshmallow Expert
MSgt Rick's Avatar
Breaker?
Sometimes it's the simple things, as was in our case on one trip where I discovered that I had forgotten to turn the breaker to the water heater back on. When there is power, the water gets hot in about 30 minutes.
Rick & Stephanie
2019 Toyota Tundra Crewmax TRD Sport
2018 Salem Cruise Lite 241QBXL
Whenever I feel blue, I start breathing again.
MSgt Rick is offline   Reply With Quote
Old 07-31-2017, 08:33 AM   #11
If you have accidentally run the water heater just once on elec without water you could have burned out the element.
2015 Crusader 315rst
2016 Ford F350 SRW 4x4 King Ranch 6.7L
Houstonkid is offline   Reply With Quote
Old 07-31-2017, 09:29 PM   #12
rracer5's Avatar
X2. The attached pic is a Suburban water heater with the outside switch. If it's an Atwood heater, there will not be any exterior switch & the drain plug is at a downward angle.
X2. Breaker should be in your main power unit panel and labeled HW Heater.
X2. This is more common than one thinks. If the RV was plugged into shore power and the heater was empty, the heating element will burn out in a few seconds. This usually happens when 1- the tank plug is pulled to drain the tank before power to the heater is turned off, 2- the RV was plugged into shore power and the heater switch(s) were turned on before water was introduced to the RV or 3- water was introduced but the heater was in bypass mode (no water going to heater) when the switch(s) were turned on
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
hot water, water
