Old 09-18-2019, 07:51 PM   #1
Hot water bypass (2016 tracer)
Hello, we just got our cMoer a couple months ago and I’m starting to read up on winterization. I have been seeing where you bypass the hot water tank. But where is the bypass on my model?
Or I guess is the better question, do I have one built in. If not what’s the best way to make sure the water is out for winterization / not get anti freeze into hot water tank
afmiller is offline   Reply With Quote
Old 09-18-2019, 10:28 PM   #2
bikendan's Avatar
Please post which Tracer model you have. My 2016 PT TracerAir 255 bypass valves are under the stove, behind a wooden louvered cover.
Equalizer WDH
Old 09-18-2019, 11:13 PM   #3
They are usually behind the water heater.
There are a number of ways they've come up with to plumb the bypass. I've attached a diagram of most of them. Option 1 is the most common.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 09-24-2019, 07:27 PM   #4
Thanks, I found the bypass.
Sorry for not having the model, Iíve updated my bio with it. But itís a 2016 Primetime Tracer 2727BH
Iím assuming the one hose that is currently unhooked and has an end is the one for where I stick it into the anti freeze. What is the line coming into the water pump, is that the fresh tank line? If that is the fresh tank, should I shut off that valve as well before running the anti freeze too. Should I shut off both the hot and cold lines and open the bypass when I start to run the anti freeze through? Assuming this would allow the anti freeze to freely go between hot and cold.
Old 09-25-2019, 07:11 PM   #5
rracer5's Avatar
Yes
Yes
Yes
Turn ALL power to the water heater OFF (switches, breaker & fuses) then, go outside and remove the drain plug for the water heater to empty it (wait until its's cold first). Flush it out & leave the plug out until the tank has a chance to dry.
But remember, next year, DO NOT turn on the water heater until you're sure the water heater has refilled with water.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
bypass, hot water, tracer, water
