Old 12-24-2014, 07:08 PM   #1
Hot water heater
Hi there,
We have 2012 Primetime Crusader. The hot water heater heats the water to a little over 200 degrees! We are wondering how to regulate the temp. The heater makes a weird clunking sound also. Should it be drained and cleaned. We live in the 5 er full time.
Thanks in advanceconfused:
dogmother53 is offline   Reply With Quote
Old 12-24-2014, 07:28 PM   #2
TURBS's Avatar
Water heater temp is non adjustable
Old 12-24-2014, 07:45 PM   #3
Witch Doctor's Avatar
It sounds like you need a limit switch. Should only be around 120 or so maybe more but maybe less. Also check behind the disk against the water heater skin and make sure you have a tight and clean connection. your only 12 degrees below boiling that is not correct and very dangerous. The disk is to open and break the contact to shut it off, then when it cools it closes and completes the circuit again and either turns your burner on or electric. If it is a tankless heater I don't know, still should be a limit somewhere.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-26-2014, 06:27 PM   #4
Todouble's Avatar
Should be popping the relief before getting to 200 degrees I thought. That's a little concerning
Todouble is offline   Reply With Quote
Old 12-26-2014, 07:44 PM   #5
HOT water
Yes, we've been told about the pressure release valve. I'm very concerned about it. I've started to turn the hot water heater off now because I'm afraid it might catch fire or something.
Thanks for responding.
Old 12-26-2014, 07:50 PM   #6
Poppy94's Avatar
Quite possible your temperature controller sensor has a build up coating it thus giving a false set point indication making the water actually warmer than normal, time to clean or replace controller/sensor I would say.
Poppy94 is offline   Reply With Quote
Old 12-26-2014, 07:56 PM   #7
Why would you heat hot water?
Are you heating with propane, electric, or both? On electric mine makes a slight hissing noise. I added a light switch with a pilot light to the electrical circuit on mine to easily turn on/off when needed for heating on electric. I only turn on an hour before hot water is needed. Easily stays hot for the rest of the day's travels for hand washing.
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
Old 01-08-2015, 08:52 PM   #8
wmcclay's Avatar
Our hot water heater heats the hot water very hot, then blends in cold water before the tap. Are you getting 200 deg out of the Tap? If so WAY to hot. What is the brand and as asked before does it heat the same temp on gas as electric?
Good Luck
Wayne
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 01-09-2015, 02:49 AM   #9
dogmother, did you ever find out what the problem is or was with your water heater?
Coachmen M/H
Concord
2018 / 300 DSC
Old 01-09-2015, 05:44 PM   #10
We haven't found out why it heats so hot. I'm turning the heater off during the day. We were keeping it on 24/7. Maybe it shouldn't be kept on all the time? We live in our 5th wheel and I guess we're still getting used to it. Far different than living in a house.
Thanks for asking:
heater, hot water, water, water heater
