04-25-2012, 04:32 PM
Hot water heater recovery time
So this might be a silly question. Does the hot water tank take longer to recover when using the electric element vs. propane? On my first trip the water would heat up on electric...but once it ran out it took forever to heat back up...I switched it to propane and didn't have the problem...when taking showers and 2 kids getting a bath I need the hot water.....is this normal?
2015 Dodge 2500 Big Horn 4x4 6.4 HEMI
2015 Grand Designs Reflections 323 BHS
Reese 16K Quick Slide with Factory Rail Kit Option
04-25-2012, 04:36 PM
You should be able to use both electric and gas at the same time depending on your hw heater make and model.
but gas is faster
04-25-2012, 04:37 PM
I can use both...just seems like the water heats up faster and recovers faster when using the propane mode instead of electric mode..
04-25-2012, 04:45 PM
O I get it. Yes. Use both at he same time...gotcha. Well that clears that up...thanks I just checked my manual. Thats what I am supposed to do for quick recovery
04-25-2012, 04:47 PM
Mine seems to heat quicker with propane.
04-25-2012, 04:49 PM
04-25-2012, 04:50 PM
I use both together. Like that it is very fast and we can take 2 showers in a row and not running of hot water. The only caution you have to remember with turning the electric switch for the electric mode is: make sure that there is water in the water heater otherwise the element will burn. On my side I always turn the breaker off at the converter at the end of each camping. The switch on the water heater itself is left on all the time and I control it by the breaker only.
04-25-2012, 07:41 PM
propane much faster.
04-25-2012, 07:50 PM
If both are available we use both always.
Water is always hot and unlimited.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-25-2012, 07:55 PM
Unlimited meaning 6/10 gal max.
04-25-2012, 08:26 PM
"Unlimited" meaning I always have hot water after 4 adult showers. Guests first; then DW; then me. It is a 6 gallon Suburban. Using both the electric element and the gas seems to keep up with the demand for us.
04-25-2012, 08:43 PM
Just messing with you. Ours seem to recover from one shower in about 5 -10 minutes but there are only 2 of us using it and we never run out either.
04-25-2012, 08:58 PM
We have never run out of hot water so far using just the electric side of it. If I want a real long hot shower...I throw my towel over my shoulder and up to the bathhouse I go. Everytime I have used the TT shower..always had hot water, but I have never taken a shower after the DW has. It might be a different story then...
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
04-25-2012, 09:01 PM
A lot of newbie's forget or don't realize they are not at home with a 40 gallon plus hw heater and believe they can take a 10 minute shower on 6/10 gallons times x amount of people !
04-25-2012, 09:22 PM
Gas provides a lot more BTU's than the electric side can through the heating element.
04-25-2012, 09:38 PM
Jack of All Trades
I just looked at the specs for a Suburban 6 gallon water heater.
10.3 GPH on gas, 6.1 GPH on electric, 16.4 GPH with both. So, gas is about 1.5 times faster than gas. So, in theory, if you use less than 16 gallons of hot water per hour (about 0.25 GPM) using both gas and electric, you would never run out of hot water.
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
04-25-2012, 09:41 PM
so one quart per minute ??? ?
04-25-2012, 09:43 PM
We do take "Navy Showers" and it works just fine for us.
04-25-2012, 09:51 PM
my dw and I do to Herk but the kids head to the shower house since they think its child abuse to have to do that !
04-26-2012, 06:43 AM
We used the electric side most of the time to conserve our propane and use both gas and electric when demand becomes higher. Also we turn both off at night, to save gas and element and turn back on in the moring, usually have hot or warm water left over.
2006 Silverado 2500HD
2007 Hensley Arrow Hitch
Good Sams Club
Cedar Creek Sams President
RVing is a tough job,BUT someone has to do it!
