Old 07-04-2014, 09:23 AM   #1
thetanu539's Avatar
Hot water heater smoking
Anyone have a suggestion to stop my hot water heater from smoking? I walked around back of my TT this morning and have black smoke marks all over the camper above hit water heater and I noticed it is putting out black smoke. I do not see any debris in the burner tube. Anyone else had this problem? How do I fix?
Randy
14 PT Avenger ATI 27BBS
09 Nissan Armada
Central Ohio
thetanu539 is offline   Reply With Quote
Old 07-04-2014, 09:36 AM   #2
ryand's Avatar
Incomplete combustion.....partially clogged air mixer or orfice. How does the flame look????Big, blue and Bushy or lean and yellow???
You could also have low fuel pressure....Switch tanks and see if it improves.
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
Old 07-04-2014, 09:51 AM   #3
thetanu539's Avatar
Thanks I will try switching tanks. The flame is big and yellow with a little blue.
Randy
09 Nissan Armada
Central Ohio
Old 07-04-2014, 10:10 AM   #4
Something in the gas/air inlet tube going to the combustion chamber.
Old 07-04-2014, 10:11 AM   #5
thetanu539's Avatar
OC, how do I check that?
Randy
09 Nissan Armada
Central Ohio
Old 07-04-2014, 10:12 AM   #6
Evereddie's Avatar
Insects? Mud daubers?
Evereddie is online now   Reply With Quote
Old 07-04-2014, 10:13 AM   #7
thetanu539's Avatar
No insects I have the screens on for that.
Randy
09 Nissan Armada
Central Ohio
Old 07-04-2014, 10:16 AM   #8
Open the door and look in the tube where the gas goes into the combustion chamber. There should be an opening where the tube connects to the gas nozzle on the left. The tube should be completely clear of everything.
Old 07-05-2014, 08:46 AM   #9
thetanu539's Avatar
Update on this. It seems to be getting worse and the cause sea to be that the flame is getting bigger and bigger it is shooting all the way through he time and out the vent. Any ideas what I can do? The LP pressure seems to be fine it has not caused an issue with anything else. We have used he heat (due to a 9 month old) and the stove.
Randy
09 Nissan Armada
Central Ohio
Old 07-05-2014, 08:54 AM   #10
Shut the gas side of the wh OFF and only use the electric. It appears the gas valve is shot!
Needless to say, you're playing with fire and could set the trailer on fire.
heater, hot water, water, water heater
