Old 04-18-2014, 05:30 PM   #1
Hot water, not so hot
Is there a way to turn up the heat on the hot water tank? I fired it up for the first time, for us, it's a 2013 Avenger 191LT. Barely warm water. Am I missing something?
NorthernVandal is offline   Reply With Quote
Old 04-18-2014, 05:33 PM   #2
Herk7769's Avatar
Your answer is here:
http://www.forestriverforums.com/for...tml#post590946
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 04-18-2014, 05:33 PM   #3
You might be facing the same thing I am. Bypass valve, but I don't know where it is. If you find it, turn it and see what happens.
Tampajohn is offline   Reply With Quote
Old 04-18-2014, 05:35 PM   #4
Broadway Joe's Avatar
It should be on the back of your water heater, which may mean opening a panel. It would also help if you mentioned what type and model tt you have.
Broadway Joe is offline   Reply With Quote
Old 04-18-2014, 06:09 PM   #5
I have all three valves open is that what I should have?
Old 04-18-2014, 06:14 PM   #6
Center valve should be closed. See Pic
Old 04-18-2014, 06:14 PM   #7
OK, nevermind. You guys are awesome. I closed the mid bypass and ran it, hot as hades. Good to go. Thanks everyone. I think I may just make this this happen, lol
hot water, water
