Old 03-20-2021, 08:54 PM   #1401
First check to see if your springs are flattening out. If so replace them. About $200 for parts.. Consider springs with more weight capacity, ie another leaf. It will be a rougher ride.
If not flattening, then add a Lippert correct track lift and Morride x factor cross beam or add a two inch box tube beneith your frame by a professional trailer shop. Weld on new spring hangers. Probably change out shackles too. Be sure ro take a look at your spring equalizer for wear around the bolt holes. Either one will probably cost $1500-$2000.
As far as the wear on the floor of the slide from the rubbing. Get a sheet of thin metal from the hardware store. Cut big enough to cover the wear spots. Add a bunch of silicone caulk and screw around the perimeter to make a watertight seal.
Randy-2198 is offline   Reply With Quote
Old 03-25-2021, 09:52 AM   #1402
2019 Sanibel 3402WB
2016 Ram Dually 6.7 HD
Since Oct 2019
colet581 is offline   Reply With Quote
Old 03-25-2021, 11:34 PM   #1403
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
MMartin, mine did come with the heavy duty suspension as had on the touring units. Came with heavier duty axles, 16 inch tires, rims, and I assume slightly different springs. The giveaway is the yellow loading total gvw sticker is 2900 lbs heavier than the unit I looked at with the 15 inch, and similar gvw as the then offered limited touring edition package. As weighed, I am typically almost 2.5k under sticker ready to camp mode.
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
Paulie1138 is offline   Reply With Quote
Old 04-01-2021, 10:09 AM   #1404
Nitescan's Avatar
2016 purchased 3/16/21
Nitescan is offline   Reply With Quote
Old 04-01-2021, 11:15 AM   #1405
New to me 2013 260 RLD
Recently purchased a 260 RLD that needed some minor repairs along with needed suspension work. Picture shows I am nose high currently but this should get closer to level once I decide what suspension fixes to do.
Name:	Crusader drivers side.jpg
Marc in sunny California
2013 Crusader 260 RLD
2012 RAM 2500 Laramie CTD and 4:10
mmartin_tdc is offline   Reply With Quote
Old 05-16-2021, 01:51 PM   #1406
We purchased our 2017 Prime Time Crusader 295RST in Sept. of 2020.
We tow with a 2017 F350 4x4 Crew Cab Long Box, gas engine
CraigJean is offline   Reply With Quote
Old 05-20-2021, 09:25 AM   #1407
Originally Posted by grhodes50 View Post
Just in the last 6 months or so it seems like quite a few of us have become Pime Time owners. I'm curious to know how many of us there are. Post what unit you have and purchase date and let's see if we can get a decent count.
Trailer: 2011 LaCrosse 303 RKS
Purchase Date: 11/06/2010
P.S. Just for fun M109Rrider and I placed PT Crew Member Since MM/YYYY in our signature. Do the same if you want.
Tracer Breeze 19MRB purchased on 5/21/2019
2018 Chevrolet Silverado 2500HD LT Z71 4wd crew cab 6.0L w/4.10
AK Fish is offline   Reply With Quote
Old 05-22-2021, 03:19 PM   #1408
Prime Time Owners
2021 Avenger 16FQ
Rkhoyle is offline   Reply With Quote
Old 05-29-2021, 04:58 AM   #1409
Purchased our first camper. 2021 Avenger 26bk. Towing with a 2019 Ram 1500 classic big horn.
JGleason is offline   Reply With Quote
Old 06-06-2021, 02:36 PM   #1410
Just got ours!
Tracer 22RBS
slharman1 is offline   Reply With Quote
prime time
