Old 02-23-2012, 10:03 PM   #1
how much pressure
How much water pressure does the fresh water pump put out? Or for that matter how much pressure from the spigot? I think my flush valve on my toilet is leaking. I pulled it off and dont see any cracks. I can't blow through the valve. Maybe its the fitting or the hose itself. I thought about hooking the hoses back up and not put the valve back in the toilet and see what happenes.....
imabmwnut is offline   Reply With Quote
Old 02-23-2012, 10:11 PM   #2
Most water pumps will shut off before or at 50 psi. If you have a regulator hooked to your city water inlet, (separate item, purchased or included in start kit), most of those regulate at 40 psi.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-24-2012, 05:29 AM   #3
Mountainmanbob's Avatar
(flush valve)
mine also is leaking
gives an occasional spurt onto the floor ???
also thought about taking the toilet (flush valve) apart
have not done that yet
did replace some other cheezy hoses that were leaking
Mountainman
Mountainmanbob is offline   Reply With Quote
