Old 07-17-2014, 01:02 PM   #1
how to adjust awning? rolls up uneven
i have the dometic electric awning. it seems to be alittle off on the awning tube by about 1/2 inch to 1 inch. it works fine.. but are there any adjustment instructions on getting it perfectly even on that roller tube? i have searched and searched..thank you
yankeeslover is offline   Reply With Quote
Old 07-17-2014, 01:06 PM   #2
Deploy the awning and center the material on the tube and pop rivet the hem on both ends.
Name:	Pop Rivet in Awning.JPG
Old 07-17-2014, 01:16 PM   #3
how do i move the material? do i just pull it?
Old 07-17-2014, 01:33 PM   #4
Yes, it may take a helper, but it really isn't too difficult. Don't extend it out to the very end like in the picture, but to about 1/8 turn before where it is in the picture.
Old 07-17-2014, 01:37 PM   #5
so i go on the short end and just pull it real hard? and do i make it perfectly even with same distance on each end of tube? and why the rivet? does it hold it there? i dont have a rivet gun with me.
Old 07-17-2014, 02:11 PM   #6
Go to the end that has the most roller exposed and pull the material to where it is centered on the tube, roll it in and then back out and see that it stays centered. If it doesn't, center it again and pop rivet or get a smooth head sheet metal screw and install on BOTH ends. Yes, the rivets/screws will keep it centered.
Old 07-23-2014, 08:22 AM   #7
I was unable to move mine at the roller no matter what I did! I did find it very easy to move at the trailer itself though...
dapersico is offline   Reply With Quote
Old 07-23-2014, 11:04 AM   #8
me either..i could not move at roller either.im just gonna leave as is
Old 07-23-2014, 11:41 AM   #9
rracer5's Avatar
My last TT had the same problem but not enough to cause a problem when rolling up. I too couldn't pull it on the roller. But, I could pull it in the channel on the TT if I took out the 2 screws they put in to keep it from moving. I didn't take them out to move it because then I knew the problem was on the roller end. I just never took the time to really get into it to re-center it on the roller. Seems to happen when you keep the awning at an angle for water run off and the wind "buffets" the awning around causing it to slide up the roller.
Another good reason for OC's awning poles and tie-down system.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 07-23-2014, 11:43 AM   #10
DDC
DDC's Avatar
I moved mine so it was even on each side but it still wrinkles when rolled up, it is twenty feet long and the tube has a banana shape, never really noticed it till after our first trip, tried to get it fixed under warranty but FR replaced the awning material only so the new awning material rolls up wrinkled to, they have a spec for tube replacement but mine did not quite get there.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
awning
