Old 10-27-2014, 10:13 AM   #1
DKRITTER's Avatar
I think I have a screw loose.
What do y'all do for those occasional stripped screws in the trailer?
Especially the ones that go into the walls they present the most challenge due to the wall being so thin.
DKRITTER is offline   Reply With Quote
Old 10-27-2014, 10:30 AM   #2
ColoradoRick's Avatar
Easy peasy...get some wood glue (I like Gorilla but Elmers wood glue is good, too) and a few toothpicks.
Dip 1-2 toothpicks into the glue and insert as far as you can into the hole...cut off any sticking out so it's flush.
Either wait for the glue to dry or, for a more permanent hold, screw into the hole while the glue is wet.
My father-in-law taught me this trick!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 10-27-2014, 11:02 AM   #3
(Dry Huunday)
DreiHunde's Avatar
^^ Ditto! Works like a champ!
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
DreiHunde is offline   Reply With Quote
Old 10-27-2014, 11:32 AM   #4
DAISY BOYKIN's Avatar
Loose screw!
I'll have to agree with you DKRITTER, I believe you have a "loose screw"!!!!
And I have to agree with ColoradoRick about the fix. You can also use a
shortened golf wooden "T" inserted into the hole full of Gorilla Glue. Just follow the directions on the Gorilla Glue container about wetting the surface to be glued or it will not work!
Good Luck
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 10-27-2014, 11:33 AM   #5
The tooth pick or golf tee trick works well when the hole needing repaired is thick enough. The thin lauan plywood that I have had to modify or repair holes in has been too thin for that trick. In those cases what I do is glue another piece of the lauan to the back side of the hole. Once the glue set drill a pilot hole and I am good to go. If that hole stips then I do the tooth pick or golf tee.
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 11-04-2014, 02:09 PM   #6
Ddubya's Avatar
The biggest problem I have with stripped screw holes is on the fenders and side panels. I just cut a small piece of hardwood and place on the backside of the panel to place the screws into.
Ddubya is offline   Reply With Quote
Old 11-04-2014, 02:14 PM   #7
wicked1's Avatar
Take a dremel and cut a slit in the stripped Phillips screw then you can use a regular slotted screwdriver to remove it, had to do that on a few occasions. I put a piece of duct tape around the screw in case the tool slips
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 11-04-2014, 03:39 PM   #8
WFD
That's funny....the DW tells me all the time that I have a few screws loose, but I haven't been able to find them yet!
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-04-2014, 03:47 PM   #9
Just insert a shallow plastic insert made for thin plywood paneling.
Old 03-15-2015, 08:51 PM   #10
Get a rivet gun and an assorted box of rivets. Always useful in times of repair.
cybertek911 is offline   Reply With Quote
