01-26-2013, 08:21 PM
I'm in love with Sanibel 3600
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
01-27-2013, 01:10 AM
Its a great unit, we love our 3500. we looked at the 3600 but decided the 3500 best fit us. Prime time has stepped up twice for us, way beyond what was necessary. Its a great company, Make sure the cabinet doors near the slides are secured with something before opening or closing them. They will destroy anything in the way, dont ask how I know. The more you know about the unit the more you will like it. A LOT of people come up to us in campgrounds and ask Sanibel??? then they want to look inside. Most are amazed. If this sounds like a sales pitch, I do not own stock, its just a great unit.
Wayne and Donna
Wayne, Donna
2016 Ford S/D Platinum 350
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
01-27-2013, 02:50 AM
One thing I found when I was looking and after I bought my Crusader... PTM customers are loyal and love their trailers.
I really like the Sanibels and am very jealous of you both. Maybe in 5 or 6 years I'll be able to upgrade to one.
Congrats on your new 3600 ThunderRoad!
Here's wishing you many nights of happy campin!
Dan n Dione
TV: 2012 Ram 3500 Laramie CC LB 4x4 DRW
RV: 2013 Crusader 325RES Touring Edition
Days Camped: 2012 (3) 2013 (22)
Next Trip: Mission Bay, CA 6/6 - 6/9
02-04-2013, 10:44 PM
New Member
We just bought a Sanibel 3600 and we are so excited to pick it up. We fell in love with it the minute we walked into it. Does anyone have any problems with theirs or any hints of stuff to look out for when we pick it up?
02-05-2013, 08:51 AM
Search these fora for "Sanibel". You'll find a few tips.
02-09-2013, 03:38 PM
Sanibel 3600 new owners.
We just traded for the Sanibel 3600 in love with it. Saw it at rv show had everything we wanted. Put a washer /dryer in it. that was important for me.Will get it next week. Dealer picking up our trade in and bringing Sanibel down. Have a spot at a campground for now. Husband in Air force and we want to travel alot when he retires. We are Happy Happy Happy
09-14-2013, 07:06 AM
We purchased our Sanibel 3600 in August and have taken 2 trips to the Gulf Shores in Alabama since. We love RV and surprisingly there was the same RV in the campsite next to us on our last trip. He loved his also. My only concern regards my truck. I have a Chevy Silverado 2500 with a diesel/ Alison trans and wonder if this truck is too small to handle the payload on the rear axle. The truck has no problem pulling the Sanibel but the rear drops about 4 - 5 inches when I hook it up? What are other Sanibel 3600 owners using to pull their RV?
09-14-2013, 07:38 AM
Denver, CO
I would hazard a guess that you are OVER your payload on the truck and that is the reason for the sag. You may be over on your rear axle rating also. BUT all this is mere conjecture and easily figured out. Get to a CAT scale, which are almost everywhere commercial trucks run. It is easy to do and will tell all. look here for post on what to weigh, as you need to do both with and without your rig and loaded up the way you normally use it.
At more than 12K dry that is one big beast to haul with a 3/4 ton. The duramax and allison is certainly up to the task, but the suspension and frame may not be.
Good luck.
2017 Fuse 23T
09-14-2013, 07:39 AM
Air bags, add a leaf or buy a 3500 ...dually for maxstability. Any will improve the experience. It is a question of what works best for you. The frame and axel are the same on 2500 and 3500.
2014 295rst TE Champagne
09 GMC 2500HD D/A
09-14-2013, 07:56 AM
Denver, CO
Frame I can can believe, axle and springs not so sure. Can you back up that claim with data? I thought that the rear end ratio's were different to. And I guess you can just overlook the ratings, they are just guidelines anyway. I'm sure everything will be OK.
2017 Fuse 23T
09-14-2013, 09:15 AM
Hi:
I have a dodge 2500 2x with a 6 speed.
I am 750 lbs over on gcvw, as I have put larger bakes on the trailer this does not concern me at all. I weigh 2980 empty and 5660 loaded on my drive axle. Rated for 6010 and tires for 6084 lbs. Trailer axles weigh 10,960 rated at 14,000 lbs. This is ready for a weekend, 3/4 fuel, full of water, propane, Honda gen and firewood.
It is best to weigh your unit, you will be surprised at what you find. Enjoy your unit it is a great trailer. The 3600 weighs about the same depending on options
Wayne and Donna
Wayne, Donna
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
09-14-2013, 03:18 PM
Springs are obviously different, 1 more leaf 3500. Rear end is 3:73 same part 2500 and 3500srw on the duramax trucks. The dually has larger brakes.
Call the dealer for a lookup if you need data. Not going to argue manufacturer ratings vs what is legal as that varies place to place.
09 GMC 2500HD D/A
09-14-2013, 10:52 PM
Oklahoma Proud
Brakes, u joints, , tire sizes- which affects final effective gear ratio, rear spring packs and or spring rates, and torsion bar spring rates, torsion keys and im sure a few other things im forgetting are all different between GM 2500hd and 3500hd trucks.
Oh and on single rear wheel, available wheel and tire sizes are different. 2500hds have 17", 18", & 20" wheel / tire combos. 3500hds have 17" and 18" wheel tire combos only -no 20". For some reason 18" tires seem to have higher load ratings, my nitto 18s have a 4080lb load rating on an E rated tire.
Ps. Work at a Gm and Toyota dealer
