Old 03-24-2015, 09:35 AM   #11
Mr. Dan's Avatar
Originally Posted by geotex1 View Post
Yes, you bring it through the screen. The problem with the Camco fridge inserts is that they are woven mesh and not welded. So when you go to trim them for this, you need to be cognizant that each "thread" is free to move so your cuts must be wise. A little trick is to get some JB Weld and mix up a small amount and spread it over a slightly largely area than you'll trim out. It'll keep all the threads in-place and not be noticeable at all when mounted.
Mr. Dan, they are not internal for the fridge vents. The screens mount on the outside and are retained by zip ties. Once installed, you can barely tell they are there. I can take some photos if you'd like.
I have the pics. Thanks. My terminology is ambiguous. They are tied up under the rows of vent holes but are not as visible from 6' away as are the truly external versions of furnace and water heater screens. I'll look into the JB Weld tip as my parts order including these screen strips is scheduled to ship today.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 03-24-2015, 11:08 AM   #12
geezer with gadgets
757Dave's Avatar
Thanks Geotex1. I figured that was the correct thing to do, but just wanted to check with someone with experience.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 48
757Dave is offline   Reply With Quote
Old 03-24-2015, 11:17 AM   #13
BamaBob's Avatar
Yep, if it is a opening, screen it!
We even pulled the covers on our 2 A/C and covered the vents with screen door screen (metal tape is your friend here )
One place some folks forget as well is your propane vents - yeah they are small openings but go ahead and put some fine mesh over the inside (again use metal tape) it is amazing how the smell of propane attracts critters!!
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 03-24-2015, 11:21 AM   #14
BamaBob's Avatar
Precisely. HOWEVER...make sure that the condensation drain for your refer still has a outlet through the vent or you could have a disaster in the making!
If the condensation drain is left inside, the water will leak down the inside wall of your refer cabinet and soak in to the wood floor...and you know what this will lead to, don't you?
Old 03-24-2015, 11:25 AM   #15
KyDan's Avatar
When we picked up our new trailer the tech giving us the pre-delivery inspection said I could drill a hole in the edge of the plastic for the drip hose
and he advised screen for the vents in the fridge hatch. I'll have to see if
the hose is long enough for that. The only reason to do that is so you can
remove the hatch without worrying about getting the hose back thru
the screen when replacing the hatch. You must have the hose outside or
it can rot out your floor under the fridge.
I used hot glue to hold flexible window screen material on the back side
of my previous fridge hatch and see no reason not to again. Ordered camco SS screens for water heater and furnace vent just now from Wally World.
Free pickup in store but I never get out of there without buying something
else
Also BE SURE the drain hose has a screen over the end or a mud-daubber can clog it right up!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 03-24-2015, 11:30 AM   #16
Flybob's Avatar
Suggest a small piece of vinyl tubing, hose or plastic pill container with bottom removed just larger than the drain hose. Permanently mount this through the vent and screen and seal around it with JB weld or silicone. Then simply slide the fridge vent through it when installing the vent.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-24-2015, 11:43 AM   #17
keeprr's Avatar
First thing I did after taking delivery Saturday of our new Mini Lite 2502 was to buy Bug Screens for the Refrigerator, Hot Water Heater and the Main Heater. In Oklahoma these are mandatory. I went to Camping World and bought items for the specific manufacturer, ie: Dometic refrigerator, Atwood Hot Water Heater. All fit perfectly and simple to install.
keeprr is offline   Reply With Quote
Old 03-24-2015, 11:51 AM   #18
geezer with gadgets
757Dave's Avatar
Another newbie question. Which vent do you use to put the drain line through? Top, middle, bottom. Left, center, right? Help is greatly appreciated!
Old 03-24-2015, 11:55 AM   #19
geotex1's Avatar
Whichever one can be reached after you bend a U in it to form a P-trap to keep critters out of the fridge.
PS - no problem taking out/putting through my tube with just a cut screen.
geotex1 is offline   Reply With Quote
Old 03-24-2015, 11:55 AM   #20
The easy method of screening out the insects is just get alum screen wire and attach it inside the vent covers, works for the water heater and the refrigerator. This works great for everything but the furnace. If you have a Norcold refrigerator, the drain tube does not to thru the vent holes, it goes into a pan above the heater and is evaporated and as such does drain outside the compartment. Don't know why you couldn't do the same with a Dometic and keep the hose from going thru the vent.
Name:	Water Heater Door.JPG
ID:	72091   Click image for larger version
ID:	72092   Click image for larger version
vent
