Old 10-30-2015, 03:55 PM   #11
on_the_bayou
PrimeTime's Avatar
Originally Posted by PrimeTime View Post
AtlantaSupply.com
Stock #: 60GHFFW12X06
12x6 White Fil. Return
Wall Ceiling Grille 1" Filter
Stamped Steel 60GHFFW
The vent does not come with a filter. I used a filter with a plastic mesh on back side so it would not get sucked into the duct.
The filter was found at Amozon. I cut it to fit the grille frame.
Amazon.com: WEB WPLUS Eco Filter Plus Adjustable Air Filter, 1-Pack: Home Improvement
I need to correct my post.
When I read the post about AC Filters, I looked up my invoice and used the wrong info.
I accidentally ordered the wrong size vent and had to return it and order again. The correct vent is;
Stock #: 60GHFFW14X08
14x8 White Fil. Return
2012 Crusader 290RLT
2012 Silverado 2500 Duramax (175,000 mi)
Camping:
2012: 4564 mi 31 days - 2013: 6277 mi 38 days
2014: 5146 mi 38 days - 2015: 1200 mi 9 days
2016: 342 mi 2 days - 2017: 2734 mi 22 days
PrimeTime is offline   Reply With Quote
Old 10-31-2015, 08:00 AM   #12
07 ThunderRoad's Avatar
Thanks for the info. Screws are stripping out on or unit. Do the latches on the grills stay closed when towing?
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 10-31-2015, 09:43 AM   #13
rracer5's Avatar
And did you have to trim out the opening on the ceiling or did the vents fit right in?
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 10-31-2015, 03:10 PM   #14
on_the_bayou
PrimeTime's Avatar
I had to trim very little of the opening mainly just to make it square.
The grille needs 12 x 6 opening and is 1.25 in high. This made it close to the top of the duct so I placed a small piece of wood (6.5 X 1 x 1/2) across the grille in the duct to keep it open for airflow.
I have never had the grille open while traveling but I always check before opening the slide outs.
Camping:
