Old 10-27-2015, 02:29 PM   #1
Inside AC filters
What do y'all do when changing AC filters in the ceiling? We have been just removing the filters and putting in new ones, only problem is that the screws are very hard to reinstall and some of the holes have begun to strip out. Anybody know of a quick change filter system?
NotQuiteYet is offline   Reply With Quote
Old 10-27-2015, 04:01 PM   #2
TURBS's Avatar
Be nice to know year make and model of the unit your working on.
Otherwise most people including me have no idea what your talking about.
Including the a/c you have.
Pictures never hurt!
Old 10-27-2015, 04:29 PM   #3
heavynlori's Avatar
Inside AC filters
Prime Time units come with the Dometic Quiet Cool 13.5k or 15k units as standard feature
They have no "dump" features or louvers to be open/closed to force more air to other areas - it is ducted more like central air in a S&B and it is considerably more quiet - you can actually watch television at normal decibal levels
There are two vents in the ceiling - one on each side in living area that have fixed metal grates screwed to ceiling.....have never removed ours yet so not sure what goes in there either 😉
The air conditioning comes out of several round louvered vents in the ceiling through out the rv
heavynlori is online now   Reply With Quote
Old 10-27-2015, 05:37 PM   #4
Ddubya's Avatar
It is a problem as the screws are just held by thin Sheetrock. I have thought about inserting the collapsible metal anchors so that metal screws can be used but have not gotten around to it yet.
I usually just wash the thin filter material and use it again.
Ddubya is offline   Reply With Quote
Old 10-27-2015, 09:05 PM   #5
This is what I was talking about. Unit is a 2013 Sanibel 3600 (Prime Tme)
Old 10-27-2015, 09:07 PM   #6
on_the_bayou
PrimeTime's Avatar
I found 2 (12 x 6) return air vents from atlantasupply.com
About $25 each. I bought a washable, reusable filter and cut it to fit.
Make sure you measure your opening. Atlanta Supply has many different sizes.
This eliminates the need to remove the screws each time. It makes it easy to change and/or clean the filter.
2012 Crusader 290RLT
2012 Silverado 2500 Duramax (175,000 mi)
Camping:
2012: 4564 mi 31 days - 2013: 6277 mi 38 days
2014: 5146 mi 38 days - 2015: 1200 mi 9 days
2016: 342 mi 2 days - 2017: 2734 mi 22 days
PrimeTime is offline   Reply With Quote
Old 10-29-2015, 08:41 PM   #7
This is exactly what we have been looking for. Our Sanibel has two in living area and two in bedroom, we will be ordering 4! Thanks for the input.
Old 10-30-2015, 07:03 AM   #8
BBBlue's Avatar
Which one of the return air vents listed on the Atlanta Supply website did you go with?
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
Old 10-30-2015, 07:25 AM   #9
on_the_bayou
PrimeTime's Avatar
AtlantaSupply.com
Stock #: 60GHFFW12X06
12x6 White Fil. Return
Wall Ceiling Grille 1" Filter
Stamped Steel 60GHFFW
The vent does not come with a filter. I used a filter with a plastic mesh on back side so it would not get sucked into the duct.
The filter was found at Amozon. I cut it to fit the grille frame.
Amazon.com: WEB WPLUS Eco Filter Plus Adjustable Air Filter, 1-Pack: Home Improvement
ID:	93267   Click image for larger version
Name:	Open Vent filter removed.JPG
Camping:
Old 10-30-2015, 01:31 PM   #10
AtlantaSupply.com
This is the one only in 14X8. Thanks for this information.
