Originally Posted by Panhead
I like the 303RKS and the 305RES as well as the 290RLT 5er. Not crazy about the Refer placement in that model, would rather have a shorter slide and the refer set out even with the kitchen counter. I don't know if the DW can live with that or not.
All in all this line will definitely be on the short list as they have a dealer only 20 miles away from us.
Steve
to the forum.
The 303RKS was the first floorplan that we saw and we loved it from the start. However, we did take our time to think about it and looked at several floorplans including the 305 RES, but kept going back to the 303RKS.
The 305RES is a great floorplan with a very large living area, but there are a few reasons we liked the 303RKS better.
First, my wife liked the kitchen in the 303RKS better. More counter space.
Second, the two swivel chairs in the slideout looked like a tight fit to me. In the 303RKS the chairs have more space and a small table between.
Third, the 305RES and 303RKS had the most room at the foot of the bed than any other Lacrosse's, but the linen/wardrobe slide in the 303RKS gives more room to the bathroom and bedroom.
The one thing to look out for on the 303RKS is the tongue weight. They had to move the axles back because of the entry door location which resulted in a heavier tongue weight than other LaCrosse trailers. So be sure your tv has the payload capacity to handle it.
You may have different preferences, but those are the reasons we chose the 303RKS over the 305RES. Either way you won't lose, it's a Prime Time!
Here's the two floorplans;
303RKS
Base Weight - 7,098 lb. (3,220 kg )
Hitch Weight - 953 lb. (432 kg )
Cargo Carrying Capacity - 2,596 lb. (1,178 kg )
Exterior Length - 34 ft. 10 in. (10.6 m)
Exterior Height - 11 ft. 1 in. (3.4 m)
Exterior Width - 96 in. (2.4 m)
Fresh Water Capacity - 48 gal. (182 L)
Black Water Capacity - 30 gal. (114 L)
Gray Water Capacity - 60 gal. (227 L)
Awning Size - 20 ft. (6.1 m)
Tire Size - ST225/75R15/D
305RES
Base Weight - 7,350 lb. (3,334 kg )
Hitch Weight - 749 lb. (340 kg )
Cargo Carrying Capacity - 2,140 lb. (971 kg )
Exterior Length - 34 ft. 8 in. (10.6 m)
Awning Size - 17 ft. (5.2 m)
