Old 10-04-2017, 08:37 PM   #1
Inverter location 2015 crusader 351req
I am have a issue with my inverter shutting off when off main power and running off the battery. My truck is charging the battery and the battery is staying up but the inverter will turn off for low voltage after about 5 min on the battery power. I want to check the wiring to the inverter but do not know where the inverter is located. Does anyone know where the inverter is located and know how it is wired from the battery?
I have a 2015 crusader 351req
10 Chevy Silverado 3500 CrewCab
6.6L Duramax with EFI Live Tuner with 5 levels
560hp 958 Max torque 3:73 gears
2015 Crusader 351REQ
cajun225 is offline   Reply With Quote
Old 10-06-2017, 12:05 PM   #2
rracer5's Avatar
If everything is working as it should while plugged into shore power or your truck but, as soon as you "unplug" the battery voltage drops that fast, I would suspect the battery(s). They should have lasted longer than 2 years unless it (they) went completely dead at one time. In that case, their lifespan was greatly reduced. So, I would have the battery(s) load tested first.
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
cat, crusader, inverter, location
