Old 08-29-2011, 08:05 AM   #1
M109Rrider's Avatar
Irene has left the building...carpet is wet in camper.
Minus a shutter and gutter, the house was unharmed, never even lost power. Opened the camper up yesterday and found some damp carpet. I inspected the roof, slide seals, window gaskets, etc and everything looked good. We had 50+mph winds and driving rain pretty much all day hammering that side of the camper. I'm hoping the water was just forced through the seals. The carpet is damp in the indicated area, no other water found. All the slides were in during the storm. The carpet in the slide is dry. What do you think?
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 08-29-2011, 08:29 AM   #2
grhodes50's Avatar
I would re-check that rear window real close. You might also check up on top around the seams. Remove the trim covering the screws and make sure they're caulked good.
Hard rain with sustained high winds can cause leaks where there were none before.
Hopefully you'll get some more post with support and helpful ideas that will help.
Good luck and keep us posted.
Gary & Trish
2018 Nights Camped - 5
Old 08-29-2011, 09:00 AM   #3
M109Rrider's Avatar
Thanks Gary, I'll take a closer look.
Jason and Billie
Old 08-29-2011, 09:33 AM   #4
M109Rrider's Avatar
Just looked at everything again. I'm thinking it came from the bottom slide seal in the wheel well area. The carpet on the floor was wet starting around the rear curbside wheel to the rear corner of the camper (under the overhang of the slide carpet). I know the wind was blowing hard enough under the camper that it blew my tire covers off. I'll send PT an email and see what they say.
Jason and Billie
Old 08-29-2011, 09:38 AM   #5
Rugged Brown's Avatar
Hope you get it resolved. Irene brushed through here with gusty winds, but not much rain. I was towing my fiver during the heavier rains, but lucklily no water infiltration.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 08-29-2011, 09:40 AM   #6
grhodes50's Avatar
Mine had a small leak under the wardrobe slide during a hard rain with high winds. But I had my slide open and I was out of level. High on the slide side and front.
I have had the slide open under the same conditions since with the trailer level and experienced no problems.
My experience doesn't help you much except that it does show that leaks are possible under the right conditions even if you haven't had problems before or since.
Gary & Trish
Old 08-29-2011, 10:54 AM   #7
M109Rrider's Avatar
Brandon York emailed me back with in a few minutes of me emailing him. Said its possible under such extreme conditions for water to be pushed through the seals. I'll make sure its good and dry and continue to monitor it but think it was a freak occurrence.
Jason and Billie
Old 08-29-2011, 11:16 AM   #8
grhodes50's Avatar
Hopefully Brandon's correct and you have no more problems.
Gotta love PT's customer service!
Gary & Trish
Old 08-29-2011, 11:35 AM   #9
jaxfl's Avatar
I took mine out of harms way to a sunny place and no rain. That is a lot easier way to avoid leaks.
jaxfl is offline   Reply With Quote
Old 08-29-2011, 12:05 PM   #10
CLASS "A" Senior Member
cfsoistman's Avatar
Had no problems - Coach just looked like I camouflaged it. Other than hosing it down to remove the leaves I didn't have any issues. We were very very fortunate not to have been impacted worse than what we received. We never lost any power just a couple times the lights blinked. Just a bunch of small branches and leaves everywhere. Our neighbor lost a big chunk of a tree but the county had it cleared off the road before 8:30 AM yesterday. About 50% of our scheduled work for today had to be rescheduled due to no power. Some of our crews are assisting the utility company guarding downed wires.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
