Old 07-17-2014, 10:22 AM   #1
Is roof cleaning really required? so much missinformation going around
first off i want to apologize for starting this on a new thread.. figure be easier to get responses this way. I am getting on my roof for the first time ever this weekend on my camper at my seasonal site.. i want to sweep off all the pine needles and just a quick looksee on my tracer 2670. I have read sooooo many different epinions on roof washing. Some people say that epdm roofs do not require any type of washing and that frequent washing may in fact shorten the lifespan.. I have spoken to dicor and they advised that if i dont clean it then that will shorten that lifespan and that i am required to scrub it off 3-4 times per year... I just dont know what to do.... the girl from Dicor did advise to just get up there with Ultra dawn soap and a medium bristle brush and clean it...im assuming that i should listen to the girl from dicor over the internet community? im confused..thanks
yankeeslover is offline   Reply With Quote
Old 07-17-2014, 10:38 AM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Good question,
I believe it largely depends where you are.
We for instance are in a very dry climate with hot summers and cold winters and I am more concerned about the seals than cleaning the roof. A rubber roof might also require more care than a fiberglass roof, but under no circumstances should a roof be ignored.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 07-17-2014, 10:49 AM   #3
dcheatwood's Avatar
Did mine this morning. I hate it. Getting ready for Goshen.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 07-17-2014, 10:50 AM   #4
TURBS's Avatar
Minimum twice a year. Period.
Old 07-17-2014, 10:54 AM   #5
VinceU's Avatar
X2- All mfgs of my 5 units called for roof cleanings periodically. If for no other reason cutdown on the streaking, esp on paint surfaces below.
VinceU is online now   Reply With Quote
Old 07-17-2014, 11:02 AM   #6
LittlePM's Avatar
I was advised that every few times that you wash your RV you should wash the roof, because what good is washing with sides if all the stuff washes down off the roof onto the sides. I would think that if you have a lot of pine needles you would want to wash that off so it doesn't eat the roof.
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 07-17-2014, 11:13 AM   #7
Arefbee's Avatar
Hate how crummy it looks since the trees have been leaving all kinds of dirt on the roof since spring but also been too busy to get it done. Thought about doing it in a thunder storm last week but then realized if I got hit by lightning my wife would kill me.
(Hate doing it, love the results!)
This weekend it shall be done!
And yes at least three times per year - Spring, Summer, Fall (under cover in Winter). I have UV protectant to apply next time.
2011 PrimeTime Tracer 2600rls
2001 GMC Yukon XL 2500, 6.0L 4.10:1 axle ratio
Nights camping 2014 - 17
2013 - 15
Arefbee is offline   Reply With Quote
Old 07-18-2014, 10:04 PM   #8
wmcclay's Avatar
Getting up on a roof to wash it means much more than just washing. As you wash it you will be inspecting it for bubbles, open spots and seals around penetrations. So wash it at least twice a year.
Good luck
Wayne
Wayne, Donna and Moab
2016 Ford S/D Platinum
2013 Sanibel 3500
Honda 3000 si
4 6 volt batterys
wmcclay is offline   Reply With Quote
Old 07-18-2014, 10:30 PM   #9
3 years on my Roo. Haven't washed anything yet. Don't know when I will. Most CG's don't want you washing while camped. TT isn't stored at home, so really no place to do it.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 07-19-2014, 01:54 AM   #10
sail2liv's Avatar
Use the cleaner/treatment that the dealer uses ..... twice a year....spring just before summer and fall just before winter.... its about $ 50 for gallon....I think you are required to clean/treat it once a year to keep warranty in effect.....good luck I get 4 washes out of the gallon.....is quick and easy to do.....save sales slip in file and put date you clean/treat in case of any warranty work required.....
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
roo, roof
