Old 04-16-2015, 07:34 PM   #21
looks like the screw was sticking outand broke when the slide was put in. chances are part of the screw is still deep inside, thats why you can,t put another one in. sealing it will be fine. if you are confident you could drill another hole about 2inches beside it and add another simular screw and add some white paint too match.
muskoka01 is offline   Reply With Quote
Old 04-16-2015, 08:00 PM   #22
B47
Originally Posted by DDC View Post
Surely it does not require a screw, Q A would have caught an error so blatant!On a more serious note it looks as though the head has come off and got scrapped causing the mark gouged into the trim.
I was thinking the same thing about QA catching it - Not.
Old 04-16-2015, 08:17 PM   #23
Would you guys worry about the exposed fiberglass and the wood it attaches to? you can cleary see its exposed even when i screw the trim down. i might add an extra screw closer to the end.. it should seal that down tighter, but im afraid to make it worse.. this trim still allows water to hit that fiberglass wood backing... and guys, i suffer from OCD, which is why i worry about things that maybe I shouldnt worry about.. I am positive i can fix the trim with butyl tape tomorrow and a bead of silicone, but it still doesnt completly cover that exposed fiberglass and backing and I know once that gets wet im screwed..instant delamination..
yankeeslover is offline   Reply With Quote
Old 04-16-2015, 08:24 PM   #24
Platokidd's Avatar
I would seal the wood with Acrylic or similar water proofing.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 04-16-2015, 08:29 PM   #25
Brother Les's Avatar
Calm down about the screw.
You should be more worried about re greasing your wheel bearings and making sure that the brakes are adjusted correctly. out a sealant over the screw head and let it go...
Brother Les
Old 04-16-2015, 08:34 PM   #26
You should be more worried about re greasing your wheel bearings and making sure that the brakes are adjusted correctly. Put a sealant over the screw head and let it go...
X2!
Old 04-16-2015, 08:38 PM   #27
Its not the screw im worried about Brother LES, Its the exposed fiberglass and the wood backing of the fiberglass... its exposed even when this trim is exposed.. im wondering if there is a way to protect that exposed wood that you can cleary see...im sure its getting wet when it rains.. that end of the trim is not sealing completly down even with a screw there.. thats what im worried about.. i just dont want rain water hitting that fiberglass wood and then delmaniation. but i also hate to take this to dealer if its an easy fix on my own..this is where im torn.. and looking for suggestions... how do i protect that wood that you can see?
im shocked that primetime has not caught on to this... there is no way that the trim without silicon protects the bottom of the fiberglass... its clearly exposed with the trim..... thanks again folks..this board is great.
Old 04-16-2015, 08:52 PM   #28
silver's Avatar
Since you have pulled the trim back/off it could be loose. Would not want it to get caught in the slid frame when you put the slide in. Get a number 8 x 3/4 inch self tapping stainless steal screw and put in with a pistil drill. Put it in about 1 inch away from old hole as the head probably broke off as others have said. The head may have broke off at factory due to over torque. New screw should be fine. That is what the dealer would probably do with the exception of the stainless. They would use a normal screw so you could watch the head rust.
Get a box of screws. You will find a use for them before you are done with the trailer.
silver is offline   Reply With Quote
Old 04-17-2015, 09:43 AM   #29
I think im more comfortable
letting my dealer do this... Alpin Haus is a very known company in this area. I suffer OCD and would constantly question my work if i attempted it.. I am really not good at fixing things. I cant imagine this taking the dealers techs more then 1 hour to fix and im sure they will make sure its sealed up correct and use the correct stuff.. I will suggest when i show it to shop manager about putting another screw towards the end to get this flush..
I also asked him about the darco tape that is fraying around that area also. he said they fix this by gorilla tape and they never get the campers back.. RVGUY says the bottom wood is waterproof already and that darco tape on the edge is just added protection... now i just wonder how much the dealer is gonna set me back... but even if its a couple hundred dollars, its worth it to me for piece of mind... I also sent pictures to rick at PT... maybe they will chime in on this and help cover some of the cost...who knows...warranty ended last year...
Old 04-17-2015, 09:58 AM   #30
I think you SHOULD take it back to dealer to help calm your mind down and let them fix it . It's not a big fix but I feel you would be more confinite having them do it.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
