Old 04-22-2012, 04:30 PM   #1
Rustymax's Avatar
Location: Close to North / South Carolina border and Blue Ridge Mountains
Unhappy It was only flat on the bottom!
Took the LaCrosse 303 out for the maiden trip and had a small mishap. While at the fresh water station, I was moving the trailer up to the fill hose position and accidently clipped a wooden curb with the trailer wheel, puncturing the side wall. A loud bang was heard http://www.forestriverforums.com/for...ies/crying.gif and to my chagrin the tire was flat (but only on the bottomhttp://www.forestriverforums.com/forums/images/smilies/eek.gif) and un-repairable.
Naturally it was raining, and getting dark fast but fortunately I was carrying a "small" (very small) floor jack and a 4 way lug wrench. It was difficult to get the tire up off the ground but I was successful and put the spare tire to better use than that of a rear bumper ornament.http://www.forestriverforums.com/for...s/thumbsup.gif Once the trailer was setup at the site, I then drove home (about 90 miles) to purchase a replacement tire and get a good night sleep.
I now have some questions for the forum members and if RVguy has trailer specific answers for this particular model RV please fire away.
• In the above scenario, is a bottle jack the best tool for jacking up the trailer of this weight, approximately 7,500 lbs?
• Is there a recommended jack (model/style) that I should be using? (particular to Lacrosse 303?
• Is positioning the jack under the axel of the flat tire the right location for lifting the trailer?
• Do I need a torque wrench for the lug nuts?
We expected being newbie's to camping with a travel trailer that our fist trip would be a learning experience, but this was almost an overload. With exception of the flat tire (in the rain), our first trip could only be rated as "first class". We were the only "Prime Time" unit at the campground, no one knew what Primetime offers and I must admit that we had many visitors who wanted to "check it out", all were impressed. It was like an open house event.
This first camping experience was a boondocking one, no water or electric, but we did have a portable generator. Our next excursion will be mid May at a private campground that has water and electric, I'll let everyone know how the 2nd camp experience works out. Pictures will be taken and posted.
Being a newbie, I'm looking forward to any advice that the forum can share.
Mr and Mrs Rustymax
Rustymax is offline   Reply With Quote
Old 04-24-2012, 12:06 PM   #2
I've been watching this closely since I am a new guy and have several of the same questions. Does anyone know the answers here or is it just use what you have and put it where it is convenient. With the axles so far apart on the Lacrosse can something like the drive on trailer aid be used?
Steve
Steve and Jan and Saidie the Jack Russell Terrier
2015 F350 Diesel Dually
2015 Cedar Creek 38FB2
h60mo is offline   Reply With Quote
Old 04-24-2012, 12:25 PM   #3
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Jack for trailer Pull or back onto this with the good tire. You will then be able to change the flat.
You can change a tire without resorting to a torque wrench, same as on a car. But you should torque it as soon as possible.
dimurrrw is offline   Reply With Quote
Old 04-24-2012, 12:49 PM   #4
I was sure hoping one of these would work. The Prime Time manual states to jack by the frame but two dealers I have discussed this with have said you can bend the lightweight frame by jacking it and that you should jack the trailer by the axle. The manual for the axle states that it should not be jacked by the axle. The trailer aid or a set of the leveling blocks stacked up looks to be the easiest solution, I was just concerned if it would work since the tires are more widely separated than on most trailers.
Steve
Old 04-24-2012, 12:57 PM   #5
AKA Bluebird
dimurrrw's Avatar
Good question. I assume that the manual and the dealers both assume the use of a jack. As far as the wheel separation, you could always put a board under the Trailer Aid to get a little more height. BTW I don't think that the axle tube is designed to take that much weight (pressure) on a single point.
Old 04-24-2012, 01:14 PM   #6
Commercial Member
You can get into specifics forever on this subject, but here are some basic recommendations for changing a flat when traveling. This is not meant to be a 100% catch-all but only basic recommendations per the above questions:
1) For safety, leave the RV hooked up to your TV. BLOCK YOUR TIRES.
2) A FLOOR JACK IS BEST since it generally has the most lifting range. A bottle jack is usually what's available and will work, too, if needed.
3) We suggest lifting between the tires on the bottom of the I-Beam frame. Be careful to not pinch wires or gas lines and get the jack squarely on the I-Beam.
4) If your jack (bottle jack probably) won't reach the frame, it is DEFINITELY NOT recommended to use the underside of the axle where it attaches to the leafspring. You need to lift on the frame, period.
5) A torque wrench is recommended for achieving proper torque. Use the star pattern. A final torque of 85-95 ft/lbs is optimal with most wheels.
RV Guy is offline   Reply With Quote
Old 04-24-2012, 01:50 PM   #7
Rugged Brown's Avatar
RV guy: My regular socket will not fit into the space where the lug nuts are. Is there a special thin walled socket available for this application? What size are the lug nuts?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 04-24-2012, 02:36 PM   #8
Commercial Member
Rugged. Working from phone. What brand and model?
Old 04-24-2012, 04:03 PM   #9
Rustymax's Avatar
Thanks all for the information. I was confused when I changed my flat tire, some campers that came to check out my problem (all more experienced than me) said jack off the frame while others said jack off the axle and my owners manual was not available. I'll go with RVguy's recommendation to jack off the frame.
RVguy, what do you think about the suggestion to use a "drive up ramp" for the good wheel to get the flat tire off the ground? Will the "EZ tow axles" design prevent the trailer from being lifted high enough to clear the flat?
Old 04-24-2012, 07:29 PM   #10
grhodes50's Avatar
Originally Posted by Rustymax View Post
......., I was moving the trailer up to the fill hose position and accidently clipped a wooden curb with the trailer wheel, puncturing the side wall. A loud bang was heard ........
Now Rustymax, you aint suppose to do that!
Man if I had a nickel.......
Glad overall the trip was "first class". I know you put alot of thought and planning into this, good to hear it paid off for you.
How did you like the 303RKS? Pretty nice, uh?
I should have told you, remember to install the X-chocks before you run out the big slide. Hopefully you had that figured out.
Man, Trish was mad at me for a week after she crawled out from underneath that thing!
Post some pics if you got 'em.
Gary & Trish
2018 Nights Camped - 5
