Old 09-23-2014, 04:11 PM   #1
GeoArm's Avatar
Jack and lug wrench
Dumb question but do the crusader 5th wheels (295rst te) come with a jack and lug wrench to change the tire?
2012 Ram 2500 Hemi
2013 PT Crusader 295RST TE
GeoArm is offline   Reply With Quote
Old 09-23-2014, 04:19 PM   #2
Very doubtful. If you have alum wheels with recessed lugs, you will want to get a post jack, thinwall socket and a torque wrench that will go to at least 110lb/ft if you have 1/2" dia studs.
Old 09-23-2014, 04:30 PM   #3
rracer5's Avatar
X2. No jack or wrench. I bought a 12 ton bottle jack and carry my torque wrench and socket all the time. Just be careful where you jack from. Besides, I'd rather use that jack for the truck also. Just don't trust the stock jack supplied with the truck.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 09-23-2014, 07:45 PM   #4
Iwannacamp's Avatar
Dang. I been worried about not having a dedicated lug wrench for the trailer. Speaking of harbor freight...hard to beat their cheapo torque wrench for lug nuts...don't forget to back off the clicker when finished. I carry a small jack already. Hmmm. It's only a two ton. I want one of those rampy things, but I am nervous about the pressure on one axle as I drive on...should I be?
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Iwannacamp is online now   Reply With Quote
Old 09-23-2014, 08:19 PM   #5
I have one of the Trailer-Aids, used it a couple of times without any problems. Works just like they advertise.
Sirsea is offline   Reply With Quote
Old 10-15-2014, 09:43 PM   #6
Will the trailer aid work with the E Z Tow axles or only with closely spaced variety?
Roamin Ovum is offline   Reply With Quote
Old 10-15-2014, 09:56 PM   #7
Platokidd's Avatar
Nope gonna need a jack
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 03-05-2015, 09:12 PM   #8
It's best not to use a jack when changing tires in my opinion. Just use your leveling blocks to roll up onto and have more height/blocks on the front axle to allow the rear axle to hang, then change the rear tire for example.
If you have ever had a flat on the side of the interstate, you will not want to trust a bottle jack on an uneven surface...especially when an 18 wheeler rushes by and your whole rig sways a few feet. I keep a few 2x6s, some long enough for the tandem and also some just enough for one wheel. Bevel the edges to make them easier to roll onto. More stability and you will feel safer.
As a side note, I have also seen folks bend up axles or their trailer itself when they attempt to jack up 6-10 tons...
cybertek911 is offline   Reply With Quote
Old 03-07-2015, 08:38 PM   #9
Send a message via MSN to Tiggerdad
Good point. Many lug wrenches will not fit the recess. I use a deep wall socket with 2 different size hex with the lug wrench to break them free. When I went to 16" from 15" the dealer gave me the socket and lug nuts needed to tighten/remove
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
