Old 06-04-2014, 07:13 AM   #1
BBBlue's Avatar
Jacking and supporting Sanibel 3500
Looking at doing some wheel maintenance to my Sanibel 3500. How are others jacking up and supporting their unit to inspect/adjust brakes and lube bearings?
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
Old 06-04-2014, 07:25 AM   #2
Ford Idaho's Avatar
I do it the same way I would as if changing a flat tire except I would place a jack stand under the axel because of the time it would be off the ground.
Jack under the spring perch jack it up enough to remove some weight off the tire and loosen the lug nuts.
Jack the tire off the ground place stand next to the jack and then remove the wheel.
Old 06-04-2014, 08:27 AM   #3
One wheel at a time by jacking about 6" behind the backing plate and a jack stand.
jbrostek is offline   Reply With Quote
Old 06-04-2014, 08:53 PM   #4
Platokidd's Avatar
x2 / thats how I did mine and I was hitch up to the tv.
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
3500, 500, sanibel
