Old 08-17-2011, 12:52 PM   #11
Edisonj's Avatar
So after I take out the window, where exactly is the main receiver in the door?
Edisonj is offline   Reply With Quote
Old 08-17-2011, 12:59 PM   #12
Luvtocamp's Avatar
It is in the actual door right in the middle below the bottom of the window. It is a little black box, there is not a lot of wire so be careful when you pull it out to reprogram.
Amy & Tom Layne
Prime Time Crew Member #31
2012 Lacrosse 318BHS
Luvtocamp is offline   Reply With Quote
Old 08-29-2011, 01:33 PM   #13
Edisonj's Avatar
Keypad programming
I programmed the new keypad to the receiver this past weekend without removing the door window. I simply removed the inside moulding and pulled the recceiver up and with a little persuasion, it came out without taking out the window. I made sure that I kept one hand on the outside of the window with pressure on it as the last thing I needed was for it to fall out and smash on the ground. I noticed that the receiver was left in the "learn" mode which is probably why it kept chewing up batteries. It probably didn't even need to be changed once I put the settings in the default position but I had the new one and wasn't taking any chances. Turned out to be a 10 minute job as you need to close the door for programming and the only way to do this without removing the window was to remove the screen door. I think it's a better solution as I didn't have to remove the window, re-caulk it and take a chance for leaks.
