Old 04-01-2013, 07:02 AM   #1
TTNewbees's Avatar
Kitchen roof vent
I have a 303 rk. My kitchen roof vent faces toward the front of the rig. All other vents face toward the rear. Long story short, I drove into a 30mph headwind yesterday and got home to a broken roof vent, the entire vent needs to be replaced.
Has anyone ever replaced one?
Is it common for the hinges to be at the rear and open toward the front?
It made it for 8 hrs into the drive but must have had a lot of resistance or popped partially open sometime after that and caught the wind.
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 04-01-2013, 07:07 AM   #2
I would guess it was installed backwards. Replace it as is and put on a Vent cover,then you can go down the road with it open,and no damage. Youroo!!
Old 04-01-2013, 07:11 AM   #3
Wait, you still have to turn it or leave it off to use a vent cover. Sorry. Youroo!!
Old 04-01-2013, 07:27 AM   #4
TTNewbees's Avatar
Thanks yooroo.
RV Guy,
Do you know if the kitchen vent should open to the rear or front of the rig? The bedroom has the hinged side to the front as well as the bathroom but the kitchen has the hinges to the rear.
Mike
2012 Lacrosse 303RK
Old 04-01-2013, 07:41 AM   #5
DDC
DDC's Avatar
I've never seen one open to the front, it's suicidal for the vent even if its completely closed. Warranty!!
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-01-2013, 08:00 AM   #6
X2 Warranty (even if its too old for that)!
Sure sounds like a manufacturing defect to me.
Old 04-01-2013, 08:06 AM   #7
bubbles's Avatar
No vent lid or vent cover should ever be installed to open or face toward the tow end or front of unit (forward). Whom ever installed yours got confused and for QC not to catch the mistake is rediculous.
Old 04-01-2013, 08:24 AM   #8
X3. And the dealer didn't even catch it??? I'd take a pic and send it to Forest River so they can see why there needs to be more quality control on the line.
Old 04-01-2013, 03:11 PM   #9
TTNewbees's Avatar
I will post pic tonight.
Any 303 RK owners out there that can tell me which way there kitchen roof vent opens?
Mike
2012 Lacrosse 303RK
Old 04-01-2013, 03:21 PM   #10
VinceU's Avatar
Sounds like a Monday car prank! Agree factory should help with that and most certainly the hing is in the front. If powered theres plenty of wire lead to turn it around.
Old 04-01-2013, 05:18 PM   #11
TTNewbees's Avatar
Mike
2012 Lacrosse 303RK
Old 04-01-2013, 05:22 PM   #12
Commercial Member
If the hinges were at the rear, this was clearly installed backwards and should have been caught at our place. Sorry for the mistake and it will be handled by warranty. If you're out of warranty and catch some resistance along the way, contact rstickel@forestriverinc.com. He will help you.
PTM
RV Guy is offline   Reply With Quote
Old 04-01-2013, 05:23 PM   #13
TTNewbees's Avatar
These were taken from front to rear, is this correct? Guess I will talk to general RV as 1 year warranty was up 6 months ago.
This is going to be expensive, as I review closer there is no way to repair it the metal arms and plastic are both broke meaning whole new vent which is cheap but a lot in labor then pray it don't leak.....
Mike
2012 Lacrosse 303RK
Old 04-01-2013, 05:25 PM   #14
Commercial Member
Easy fix - no worries.
PTM
Old 04-01-2013, 05:26 PM   #15
TTNewbees's Avatar
PTM
Didn't see your post, thanks I will take it to general RV.
Mike
2012 Lacrosse 303RK
Old 04-01-2013, 05:39 PM   #16
Worker education/instruction would be better. All QC can do is check it and write it up. The worker must be instructed and then all QC has to do is check that it is installed correctly. Worked those same type issues for 45 yrs. Management has to insist the workers know and perform their duties in the proper manner. BUT, bottom line, Quality inspector SHOULD have caught this blatant error. But so should the dealer's people, especially the person doing a good PDI. Should never have left the dealer's lot.
Old 04-02-2013, 07:04 PM   #17
TTNewbees's Avatar
Although I have only been in mfg for 23 years it is impossible to have a zero defect or preventative quality procedure. We all have good and bad days, busy and slow days. Sometimes things slip through. For me it's about satisfying realistic customer needs. I do disagree with pdi or dealer catching this. Do you try the heater in a new car on a 100 degree day? Or try a/c on a 20 degree day or verify the plumbing works when the unit had been winterized with pink bags on each faucet?
No chance of catching all potential defects on a new unit regardless of you or your dealers preparedness.
Mike
2012 Lacrosse 303RK
Old 04-02-2013, 07:22 PM   #18
...Do you try the heater in a new car on a 100 degree day? Or try a/c on a 20 degree day or verify the plumbing works when the unit had been winterized with pink bags on each faucet?...
No, but if the bumpers were on upside down, I would expect the dealers man/woman to find it. Nothing to check on the vents other than roll them up to insure they are working. Common sense would tell the tech that "Sumtin don't look rite har."
Bottom line, they didn't check the functionality of the vents at the factory or the dealer. That's the root cause of the problem getting to the customer.
Old 04-02-2013, 07:31 PM   #19
TTNewbees's Avatar
Understood, I am selfishly happy that somebody stands behind it after the warranty is dead. That goes a long way when I get my 5 er this fall.
Mike
2012 Lacrosse 303RK
Old 04-02-2013, 07:45 PM   #20
As it should be. Now, you have something else to add to your PDI, make sure the roof vents all open to the rear.
